The only solution may be an alloy billet slave from Fast Carl....
Edited by Dan, 15 September 2007 - 11:14 PM.
Posted 15 September 2007 - 11:07 PM
Posted 15 September 2007 - 11:09 PM
Posted 15 September 2007 - 11:14 PM
Posted 15 September 2007 - 11:17 PM
Posted 15 September 2007 - 11:22 PM
Masters are the same, slaves very much aren't.
As Ethel says the hydraulics are self adjusting by virtue of a non return valve in the master. This can all be caused by the system needing to settle in and you can use the self adjustment to force it all together. Wind the return stop out and then pump the pedal and you will see the point the arm returns to moves. Do this until there is almost no travel and it is keeping the clutch open all the time, then reset it back to where it has the required gap from being relaxed and no more. That should have settled all the parts into each other and get it working.
Posted 15 September 2007 - 11:42 PM
Posted 16 September 2007 - 12:33 AM
Edited by jonny d, 16 September 2007 - 12:38 AM.
Posted 16 September 2007 - 01:04 AM
Posted 16 September 2007 - 11:42 AM
If none of the above sorts it however, it is likely to be a problem with the primary gear - either one or both of the bushes has 'gummed up' and is not allowing the primary gear to rotate freely on the crank. It could also be that one of the bushes (usually the inner one) has 'walked out' and has taken up the end float in the primary gear. I've had both of these happen regularly on my Turbo before fitting the MINTEC (Calver) fully floating bush, which has proved 100% reliable
Posted 16 September 2007 - 11:51 AM
Thanks for that MS, this bit interested me:
I have this morning put a piece of rollcage tubing on the clutch arm, and tried to disengage the clutch, thus bypassing the hydraulics. Even with a good 2 foot of leverage I couldn't get the plunger to move in move, if at all. The plunger doesn't even move in enough so that the threaded portion is inside the cover!
Posted 16 September 2007 - 12:06 PM
Posted 16 September 2007 - 03:47 PM
If there is a non return valve in the master, what hapens when you release the clutch pedal? where does the fluid go?
Posted 17 September 2007 - 06:35 PM
Posted 17 September 2007 - 08:00 PM
Posted 17 September 2007 - 08:06 PM
