Is This The Rustiest Mini Ever?!
209 replies to this topic
#31 stickycreambun
stickycreambun
  • 1,865 posts
Posted 22 January 2008 - 09:10 AM
nice work. mad fool!
#32 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 22 January 2008 - 09:30 AM
Very nice work :thumbsup: How do you align the doors? I have just put mine back on and they hit the latch and don't close unless I slam it.
Is the gap even(ish) around the door?
If it isn't then the hinges will need shimming, the shims are flat rectangular pieces with 2 holes that go between the door hinge and the pillar.
Where there any shims on the doors when you removed them? You should put them back on in the order they came off
You can usually buy the shims off fleabay or make them!!
If the gaps are even and then you may have to adjust the latch plate on the door pillar(3 phillips headed screws), an impact driver is the best tool for this..
Hope this helps
Seamus
#33 Adcuz
Adcuz
  • 843 posts
Posted 22 January 2008 - 05:45 PM
Ecellent, that makes sense now. Thanks!
#34 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 February 2008 - 06:09 PM
Hi, well I've actually been in the garage working today!!
Moved Spudnik over so I could start work on the other(equally rusty) side!!
First off I removed the front wings and a panels
Attached File  spudnik_044.jpg   323.06K   53 downloads
This revealed a huge pile of rust!!
Attached File  spudnik_050.jpg   321.42K   57 downloads
Attached File  spudnik_051.jpg   323.79K   48 downloads
It looks far worse in the flesh, the inner wing is totally shot as is the scuttle corner, all these will require repair replacement.
To do the repairs I needed to remove the door, the bolts were, as usual, totally rusted, but I have a secret weapon!!!
I have a set of sockets that wil remover even the most chewed up and rusty nut, ideal for door removal/subframes etc.
Attached File  spudnik_047.jpg   325.37K   93 downloads
If you look at the sockets you will see that they have teeth which grip the nut, simply hammer the socket onto the nut
Attached File  spudnik_048.jpg   323.09K   24 downloads
The nut can them be removed as per usual
Attached File  spudnik_049.jpg   332.16K   17 downloads
This allowed me to get on with the rather satisfying task of removing the rusty passengers floor!!!! :D
Attached File  spudnik_052.jpg   322.44K   100 downloads
Attached File  spudnik_053.jpg   330.54K   62 downloads
Attached File  spudnik_055.jpg   326.04K   89 downloads
I did manage to do some welding to the heelboard
Attached File  spudnik_056.jpg   316.48K   112 downloads
Hopefully tommorrrow I will get on and do some welding.
The end is getting closer!!
#35 clubby
clubby
  • 650 posts
  • Local Club: BrEt
Posted 08 February 2008 - 06:22 PM
shiftyseamus, im pretty sure your mini will looks GREAT !~ CONGRATs to you mate... all the best next step k :D
#36 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 10 February 2008 - 05:22 PM
Hi, I've been a busy bee this weekend!!
I have finished cutting out the passengers floor.
This was considerably more rotten than the drivers side, I have had to remove quite a bit of the toe board/subframe mounts
Attached File  spudnik_059.jpg   318.16K   72 downloads
Once this was done I trial fitted the new floor - Disaster!! It didn't fit!!
The shaped sections on the rear of the floor didn't match the shape of the heelboard, I won't be able to return the panel as I got it ages ago, DOH!!
I can make it fit with some reshaping and welding but it still peed me off, so I decided to leave it and had a look at the flitch/scuttle.
BIG MISTAKE!!!
Oh boy is it rotten!!
Attached File  spudnik_057.jpg   324.72K   114 downloads
It was made mostly of filler and underseal, totally lethal.
I fabricated some new plates and cleaned back to the best metal I could find, this was then treated with weldthru primer prior to welding.
Attached File  spudnik_060.jpg   328.11K   113 downloads
Once I had done this I then welded in the replacement flitch panel.
Attached File  spudnik_062.jpg   314.65K   131 downloads
This is only tacked in at the mo as I now need to see if the door still lines up.
If all is well then I can repair the scuttle and get on with the floor, thats a job for next weekend.
I have also bought a good rear subframe, a 2nd hand bonnet, a new front panel, passengers door skin and a pair of wings for him as well, so I now have most of the panels needed ro finish the shell.
Seamus
#37 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 18 April 2008 - 03:37 PM
Looks good so far ! now stop cutting metal out before you have nothing left :thumbsup:
#38 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 18 April 2008 - 03:40 PM
Thanks, Spudnik is back in the garage now so I will be starting work on him again very soon.
Got sidetracked with Humphrey!!
Must get my arse in gear
#39 bloomers
bloomers
  • 815 posts
Posted 18 April 2008 - 03:54 PM
This is sooooooo rude!
#40 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 18 April 2008 - 09:25 PM
It will be nice when its actually finished!!
I hope!!
I may even try and get the passengers floor in this weekend!!
#41 tedmcedd
tedmcedd
  • 2,751 posts
Posted 19 April 2008 - 10:57 AM
looking good!
its easy when you have the skills! i would be better off learning how to weld, then i can repair my front....
#42 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 27 April 2008 - 04:55 PM
Ok then, I've actually fitted the passengers side floor.
For some reason the profile didn't fit the heelboard so I had to "reshape" it at little, fits now!!
Attached File  spudnik_003.JPG   329.17K   124 downloads
I then fitted the door steps and aligned everything
Attached File  spudnik_002.JPG   330.97K   95 downloads
However the floor was that rusty there were still a few gap that I had to fill.
Attached File  spudnik_001.JPG   326.18K   122 downloads
Ran out of sheet steel and had to bent over by B & Q £13 for a sheet!!!
Attached File  spudnik_004.JPG   327.84K   125 downloads
Finally seam welded the inner flitch.
Attached File  spudnik_005.JPG   323.27K   87 downloads
I think i'm about half way through now!!!!
I am happy with progress and its starting to take shape.
I am really tempted to drop the subframe so I can tidy up the toeboard and properly paint the engine/frame etc.
I 've got a week off soon so we will see.
#43 clubby
clubby
  • 650 posts
  • Local Club: BrEt
Posted 27 April 2008 - 05:25 PM
hye mate... need working hard.. good luck mate
#44 Jammy
Jammy
  • 25,397 posts
Posted 28 April 2008 - 02:07 PM
Hey, congratulations on all this work dude. Looks pretty faptastic!
But then I also secretly despise anyone who makes this bodywork malarkey look so easy! :)
#45 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 28 April 2008 - 05:24 PM
Thanks for the comments.
I hope I didn't make it look too easy, I have spent Hours and Hours just to get it this far!!
Its just a never ending battle against tin worm, however I am winning now!!
Shifty
