*Nods* Here, hereDont use hair creams they stink and dont actually do much!! rubbish
Shaving :0(
#16
Posted 28 October 2007 - 02:39 PM
#17
Posted 28 October 2007 - 02:40 PM
looks like i'll have to try it! what is it called... veet ?
yep i do, you know homer simpson when he shaves and it comes back instantly.. thats me! haha
also if i leave it 2 or 3 days it hurts when i shave it off
those gillet people say their 5 blade thingies last 3 months per pack.. i don't get a week out of a blade
So basically, if you shave it hurts and if you don't shave, it hurts. Got yourself into a position there! Get some piercings, it boosts your pain threshold!
#18
Posted 28 October 2007 - 02:46 PM
oh rightHow old are you?
29
#19
Posted 28 October 2007 - 03:48 PM
Change the razor blades often, and use a good lubricating gel or foam (I like King of Shaves), then loads of moisturiser, and I mean loads. Every time you wash, stick more lotion on.
If you do it regularly (not necessarily everyday), you should stay smooth as a baby's thingie.
#20
Posted 28 October 2007 - 03:53 PM
Don't use depilatory cream. If you are sensitive to shaving, then you'll react even worse to the chemicals in Veet. I've tried all forms of hair removal (apart from laser & electrolysis) on my pins, poobs & pits, and to be honest, a good old fashioned wet shave gives the best results & the least irritation.
what are pins and poobs?
#21
Posted 28 October 2007 - 04:34 PM
If you have to ask then you're not old enough to know & as this is a family forum I can't tell you.what are pins and poobs?
Alan...
#22
Posted 28 October 2007 - 04:46 PM
then apply your shaving gel.
Use razors with only 2 blades-mroe than 2 gives you a really close cut-too close a cut!
make sure you constantly wash the blade with cold water- makes the blade swill!
Do it fairly gently and don't press so hard-you dont need to!
Always go in the direction of the hair- pretty much always down.
Wash off with warm water and dry!
tada!
the end!
#23
Posted 28 October 2007 - 04:49 PM
#24
Posted 28 October 2007 - 04:53 PM
anyway i have to agree with JuJu and say KING OF SHAVES it is absolutely awesome. if you get the silicon oil stuff in a blue bottle it is great. really hot and wet face and ac ouple of drops of oil and it it works a treat. I also use a gillette fusion power razor
#25
Posted 28 October 2007 - 04:56 PM
Oh and the more you shave, the quicker it grows back so try and do it every other day and soon it wont grow back as fast.
That's not true!
#26
Posted 28 October 2007 - 04:57 PM
#27
Posted 28 October 2007 - 06:00 PM
#28
Posted 28 October 2007 - 06:15 PM
Shower to open up the pours....
Then make sure face is wet and apply sensitive shaving gel.....
Use a good razor (not a disposable) Quatro, Mach 3 or a Fusion (that's what i use)....
After shaving both directions...
Re wash face, I put my head over the tub and use the movable shower head to really do a good job... It'll sting at first but once you've washed all the pours it will feel good..
Then dry and use a face cream or lotion... My wife bought me some stuff from the body shop... But before that I would just use her oil of olay face lotion..... I always have a good shave and my wife likes the smooth face...
Hope this helps..
-Brad-
#29
Posted 28 October 2007 - 06:25 PM
#30
Posted 28 October 2007 - 06:29 PM
Try waxing your face lol
The more you shave the more it does grow and quicker.
xxxx
xxx
xx
x
