1970 Bay Window Westfalia
#16
Posted 03 November 2007 - 09:33 AM
#17
Posted 10 November 2007 - 12:32 AM
I did have a 71 westy from cali,sold it a couple of years ago.Your wright its just unreal the condition of them,metal wise.
Do you mind me asking what sort of money he paid for it?
#20
Posted 11 November 2007 - 07:08 PM
#21
Posted 11 November 2007 - 10:57 PM
1600 twin port on a single solex. Resoanley awsome condition, dad heard it running when he collected, said it sounded good. Goal is to get it in and get it running before christmas.
My dad (Paul) went to look at a sisters workmates 1968 bus today, see how everything is bolted and what not, got some good pictures and helpfull info. Should see some proper updates soon, E.G body work and engine fitting.
#22
Posted 13 November 2007 - 03:43 PM
We have an engine!!
Sounds good.
Do you know if the engine is unleaded?
If you looking for a bit more oomph, then 1641cc conversion is a good start and you can change the heads too unleaded then too, it's not that expencive too do either. I would stick too single carb as twin carbs on aircooled vdubs are notorious for being a pain, especially in the winter.
#23
Posted 13 November 2007 - 04:34 PM
from what i can read if it will burn then a air cooled VW engine will run on it and it doesnt care if it has lead in it or not
these engines were so basic and sold all over the world that they will run on anything and do a very high millage between rebuilds
#24
Posted 13 November 2007 - 09:33 PM
.......hi there,, all the vwub engines after 67 had the hard valve seats(or what ever the propo name is) ...so yea unleaded is not a proplarmo.....i ;v done three of these babies up-2 campers an a crewcab-so just ask away if any advice is required ...the 4 into one exhaust with jaytubes (noheat exchangers)is the cheapest way to gain a littlebit of performance, and if you have the covers on still under the van -get em off -they just hold in the wet andwill rot the sills quicker than anythingtheres a lot of talk about VW's being leaded or unleaded
#25
Posted 16 November 2007 - 05:59 AM
#26
Posted 16 November 2007 - 07:08 AM
we are making quite a collection now
#27
Posted 16 December 2007 - 07:50 PM
Update minus pictures....
My dad has fitted a new battery tray on the off side, Then when fitting the rear engine cover, he noticed the nearside was bent in, then when looking around, noticed a few bent bits and pieces, so decided to fit a battery tray that side to get the shell into its origional shape.
So, to recap - Fitted 2 battery trays, one on each side an de-greased the engine bay.
He also went to buy a gearbox yesterday, 4 speed 1600 gearbox, was an ebay find Had to go all the way to Wales thou
I'll keep you updated from now on, I'll grab some pictures tomorow too.
Next up, I think hes buying some new driveshafts for it, Still hoping to get the engine and box in there before christmas running!
#28
Posted 16 December 2007 - 07:58 PM
i don't think there's a problem he hasn't solved before
#29
Posted 28 January 2008 - 02:59 PM
Thought I should update this...
Dads finished the engine bay, well, prepping it ready for the engine and box..
From this....
To this...
So, as you can see, the engine bays been totally degreased, stripped, all welds been tidied, had a second battery tray fitted on the nearside, had abit of welding done to the arch, where the panel had split from it, but other then that, its all be cleaned, re sealed/waxed, primed, and sprayed in the origional red. All wiring has been refitted, and the rear apron has been fitted back up, after painting.
And here is the engine and box,
4 speed 1600 gearbox, should hopefully give a ocmfortable cruising speed of about 60...
Engine...
Twin port 1600, o a single solex, wantign to keep it nice an origional
Had to import a gearbox mount from america for it, no one in britain stocks them aparently Had some trouble with the clutch too, He thought a 215mm clutch would fit it, but it was to big and will soon have a 200mm clutch for it.
I think next up will be painting the tin ware, cleaning the engine up, and fitting it back in with the standard airbox.
Watch this space!
Edit: I think he's also buying some driveshaft kits for it, with all the joints an boots etc. Should'nt be to long before the engine is in!
Edited by Tom Booth, 28 January 2008 - 03:00 PM.
#30
Posted 28 January 2008 - 05:55 PM
