Reggie!
1535 replies to this topic
#601 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 06:25 PM
oh well..
timing cover will have to come back off again and I'll have to see what that bolt does without the timing plate and just going into the hole on its own
#602 Jobu
Jobu
  • 508 posts
  • Local Club: 16vminiclub
Posted 28 February 2008 - 08:07 PM
Did the bolt that isnt going in properly come out easy enough? Did it come out at a slight angle? If its been put in cross threaded then the threads are probably fecked and either need tap running down the hole depending on how bad they're or need to helicoil it. Give it a good clean and try and inspect the threads.
#603 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 08:16 PM
to be honest, I don't know how it came out, as it's right at the bottom down at the back. But i didnt have to force it to come out at all, just felt normal, to be honest.
But I'm kinda thinking that this might be my leak... It's right above the speedo cable area. When we changed that, it was absolutely coated in grime and oily stuff.
I haven't done this one up, because you can feel that it's just going in wonky... and I got a mirror down there to look at it and it's just at such an angle. But it won't go in any other way, at all!
I'm worried that its in a really bizarre place that you can't get a tap in there ;D
And I can't get the car to a garage, if it needs to be done :cry:
#604 England_expects
England_expects
  • 120 posts
  • Local Club: A-Serious & BOGMOG
Posted 28 February 2008 - 08:18 PM
Did you tighten up the other bolts before you got to the awkward one? If so, loosen them off, give the cover a 'jiggle' (that's the technical term ;D) and get that one in, then tighten the others up.
#605 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 08:19 PM
Yeah, I did that ;D
I tried tightening the others, then loosening the others... then taking all the others out and having that as the first one
But I just can't doooo it :cry:
#606 England_expects
England_expects
  • 120 posts
Posted 28 February 2008 - 08:22 PM
hmm, it's probably just coincidence that the awkward bolts right over the speedo drive. It does get nasty and clogged up with crud... though you did also find that mirror down there, so just maybe it has been the problem?
#607 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 08:25 PM
Yeah, i did think that about the mirror too ;D
Dunno :cry:
Guess I've gotta wait til the morning to see what it does and if there's anything I can do >_<
Is it possible to get a tap to sort out the thread all the way down there ? >_<
#608 England_expects
England_expects
  • 120 posts
Posted 28 February 2008 - 08:27 PM
trying to think how much space is down there. Not much, iirc? Probably could be done, though it will be tight and awkward.
Sorry, not much help, am I ? ;D
#609 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 08:29 PM
owwwww ;D
how buggered am i? :cry:
#610 England_expects
England_expects
  • 120 posts
Posted 28 February 2008 - 08:33 PM
Not completely, lol ;D
*If* the backplate threads are knackered, just swap it over.
#611 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 28 February 2008 - 08:37 PM
gonna be pricey tho, right? ;D
#612 England_expects
England_expects
  • 120 posts
Posted 28 February 2008 - 08:38 PM
Course not, you can't normally give 'em away, lol. I've got one, if you do need it - just let me know, 'kay?
#613 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 28 February 2008 - 08:40 PM
could always drill a hole in offending subframe (if possible) and get long reach or extension for the tap
#614 Bean
Bean
  • 8,054 posts
  • Name: Jean
I'm confoosed >_< How do you change it ? ;D
Fankoo, Mr Kris :cry:
#615 GraemeC
GraemeC
  • 7,473 posts
Posted 29 February 2008 - 08:31 AM
To change the backplate means removing the timing gears etc - once you have a backplate it is a cheap job but just needs time and patience - you need to make sure the cam timing is put back right. You'll also need the gasket that is behind the backplate.
To be honest with this problem and that dodgy bolt at the beginning I would replace the backplate for a known good one.
