Reggie!
#1201
Posted 16 September 2010 - 09:47 PM
#1202
Posted 16 September 2010 - 09:49 PM
#1203
Posted 17 September 2010 - 10:09 AM
GOOD IDEA PIKEY!!!!!!................what ME??.......Pick on Bean ......NEVER..........(HeHeHe)..........Me- Genius I WISH !!!!!!!!!
If you're sticking with the MPI better get the gearbox sorted...........I'll get me toolbox!!!!
can you put a double thick mega hardened layshaft in there the way she gets though em?
#1204
Posted 17 September 2010 - 12:31 PM
#1205
Posted 17 September 2010 - 08:39 PM
#1206
Posted 17 September 2010 - 09:00 PM
#1207
Posted 18 September 2010 - 01:23 PM
Bought the world's most expensive spot weld drill bit & ran out of gas in those stupid little bottles, just as I had set everything up.
Gah!
Oh well - At least I have my drill bit - I'm off to see Reggie after I've scoffed some potato salad
#1208
Posted 18 September 2010 - 07:25 PM
Got over to Reggie and started to dismantle the front end.
Managed to remove the passenger side A-Panel first, behind which, I found some nasty rust to the bottom of the hinge panel.
I then started to drill out the spot welds on the wings. For some reason (I can't remember now!) I swapped to the driver's side to do first. I think it was due to the fact that the spot welds were much more obvious on this side.
Whilst drilling them out - I realised just how much bodge has been put on Reggie - He has so much filler on his general bodywork, where there really is no need to be any filler at all! Everything I touch, just chips off in big chunks in my hand!
Anyway - Eventually got all the welds drilled out and got the driver's side wing off. I've not got the A-Panel off on that side yet, as it started to get dark.
Unfortunately, I found rot along the scuttle lip (where it meets the wing) and the part of the inner wing that I was worried about has increased from about 6cm to about 15cm - It's just rotten along the gutter lip. Really not sure what to do here yet.
I also found a large amount of filler shoved in both A-Panels, at the top, where the hinge panel attaches (Er - Or is supposed to be attached!)
I do have some photos, but they're on my phone - I will upload them later.
I was going to quickly put the inspection light on, to get a couple of detailed ones, but I managed to knock that off the shelf and smash the tube inside. So I thought I'd have a quick sweep up before I left - But as I was sweeping, the head came off my broom.
Marvellouuuus.
Still - Potato salad was nice.
#1209
Posted 18 September 2010 - 08:16 PM
#1210
Posted 18 September 2010 - 08:57 PM
Unlucky about the bodge, but it's best to find it now, and get rid of it during the revamp than have it play havoc with your new paint job
Thats the hole (you see what I did there?) idea of poking rusty bits with large screwdrivers
Get those photos up anyhoo, young lady - we want Reggie porn!
Edited by nightflier, 18 September 2010 - 09:17 PM.
#1211
Posted 18 September 2010 - 09:14 PM
Do you ever have those days where you just should have stayed in bed?
yep, normaly most days ending in a y
#1212
Posted 18 September 2010 - 09:21 PM
Karl - Cheer up!! There's always "Tomorrow"
#1213
Posted 18 September 2010 - 10:05 PM
#1214
Posted 18 September 2010 - 10:13 PM
Just the scuttle end repair and a new section welded into to the lip for the a panel to fold round.
#1215
Posted 18 September 2010 - 11:37 PM
that's much better than most! (although it shouldn't have gone after being "restored")
couple of bits of tin and thats sorted! Even the scuttle is plateable(if it hasn't spread around the corner radius :s ) and even if it has, you can get scuttle end repairs... take a bit of fettling, but they work ok.
i'd be more worried about how it's taken you an afternoon to remove a wing! At this rate you may be done by the show season 2012
