Project: JET BLACK
222 replies to this topic
#61 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 26 April 2006 - 12:31 PM
Cheers.. :trooper:
Couple more pic of inside.. drivers side floorpan and inner front arch repair
[attachment=15224:attachment]
and after
[attachment=15225:attachment]
next it was time to cut off the whole scuttle and replace it with a pattened part found at the ace of herts mini show and attched the panel on with clamps
[attachment=15227:attachment]
nice fit..
#62 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 26 April 2006 - 05:09 PM
Also the hole was cut for the weber box.. which my friend made for me. Nice and big.
[attachment=15231:attachment]
and from the front
[attachment=15232:attachment]
and from the back
[attachment=15233:attachment]
Fitted..
[attachment=15234:attachment]
From the top you can see how deep it is.. should be loads of room for a weber and filter on a 6" inlet
[attachment=15236:attachment]
painted..
[attachment=15235:attachment]
Nice
#63 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 26 April 2006 - 05:54 PM
I had to replace the Hillboard (The panel under the rear seat that the rear subframe bolts too) as a couple of bolts snapped when removing the rear subframe.. also the panel was on it last legs.
Cuttin out was a mission as its very tight down there.
But i cut the the rotton floor out, inner sill and the drivers hillboard.. and was left with a big hole. :trooper:
[attachment=15237:attachment]
from the back
[attachment=15240:attachment]
Outer sill getting welding on
[attachment=15241:attachment]
and then the finished floor
[attachment=15242:attachment]
same story for the other side... this was not a nice panel to fix...
#64 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 26 April 2006 - 06:11 PM
Slapped the scuttle on
[attachment=15243:attachment]
Just like that...
Showed that i still loved my mini :trooper:
[attachment=15244:attachment]
Then we tipped it over...
[attachment=15245:attachment]
played about for the camra
[attachment=15246:attachment]
this is nick.. my welder.. and my best mate.. cheers for all the work.
[attachment=15247:attachment]
Then painted the whole underneath with hammerite... great stuff!
[attachment=15248:attachment]
#65 HoRiZoN
HoRiZoN
  • 16 posts
Posted 26 April 2006 - 09:07 PM
good job!
just a question, you put hammerite on the bodem. what did you do before you put the hammerite? anti rust spray?
#66 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 26 April 2006 - 10:12 PM
no... scrapped off the std undersill goo off and painted a couple of layers hammerite straight on top.. should be fine.
#67 miniman86
miniman86
  • 1,939 posts
Posted 27 April 2006 - 08:11 AM
that mini is looking impressive now dave! i will have to get some pics of mine when i get it out this weekend (if it will move)!!
#68 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 27 April 2006 - 12:20 PM
Its plodding along now.. going down to work on it again 2nite. Is it that bad with yours? U not going Newquay?
#69 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 27 April 2006 - 09:14 PM
Just spent tonight attempting to force the front part of my roll cage into my car.. very tight indeed :(
Front
[attachment=15294:attachment]
and
[attachment=15295:attachment]
Back
[attachment=15296:attachment]
i know there meant to be tight.. but i didn't think it would fit.. this was in the first batch of safety device cages made in Poland... :- how safe do i feel!
[attachment=15298:attachment]
I would also like to show u my new inner pot joint things.. £30 each. no more leaking grease onto my exhaust!
[attachment=15297:attachment]
:D
#70 Mincento
Mincento
  • 443 posts
Posted 30 April 2006 - 01:29 AM
looks a really well done project
i hope you got that healbourd exactly right or it will nock ou the rear subframe which can cause problems but yeah it all looks well done
although one thing i learnt from my cinq is hamerite does not last at all it chips of way to easy i ended up ripping it off and using stone chip paint which is alot better and doesnt chip off anywhere near as easy or 'chassis black' paint is good
good luck
wayne
#71 andywaller
andywaller
  • 1,636 posts
Posted 01 May 2006 - 03:59 PM
looking really good mate, cant belive how much welding you have done. i look forward to seeing it when it is done, i will try and get to some smag meets with mine when its finished!
ps those doors look good, where they from mini door company? whats the fit like?
i am hoping my roof will fit! i am not sure how much of a lip to leave yet, probaly 2 inches, are you bonding yours on with sikaflex?
#72 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 02 May 2006 - 12:33 PM
I can believe how much weldings been done..
i bought the doors off the same guy who sold me the roof.. i'll txt him. he works night so mite geta reply later 2nite.
They fit ok.. the bottom of the door does stick out a little but once the door locks are fitted it should be fine.. they do stratch easy.
For the roof i was going to leave a 2-3 inch lip and use sikaflex.. no one will be able to remove it.. we could start a carbon roof gang..
#73 andywaller
andywaller
  • 1,636 posts
Posted 03 May 2006 - 07:52 PM
cool, they look like the mini door co ones, probably going to get some of those too! dont want it to look like i am copying you! :proud:
yeah a carbon roof gang would be smart i only know of 3 other minis with this done! they are going to stand out loads! sounds like we are going the same route on fitting the roof, the guy that sold me the sikaflex said it will set solid! i also have 6 countersink washers and stainless bolts to go at the top of each of the pillars but i am not sure weather to use these or not!
#74 Dave 1293
Dave 1293
  • 409 posts
  • Local Club: SMAG
Posted 05 May 2006 - 12:33 PM
No worries.. we both like that style. :proud:
I'm intersted in that carbon Era vent too... smudger does them.
Ok new addition for my mini this week.....
A Fuel tank!!
[attachment=15629:attachment]
Custom made.. Ally tank
#75 Jammy
Jammy
  • 25,397 posts
Posted 05 May 2006 - 12:52 PM
I hope to have a carbon roof (with a slight difference :- ) on my Vtec when its done! Yey, I can be in the gang too! :proud:
