Project Golden Balls.
303 replies to this topic
#256 R1minimagic
R1minimagic
  • 4,660 posts
Posted 11 May 2012 - 01:45 PM
You should wire something into your drivers seat so that you get a warning shock and also your DVD player so this pops up
#257 nev_payne
nev_payne
  • 2,249 posts
Posted 11 May 2012 - 01:46 PM
Oh god yes. Just the chorus even on a wired in voice box would be enough.
Edited by nev_payne, 11 May 2012 - 01:55 PM.
#258 bcjames
bcjames
  • 2,741 posts
I want one :lol:
#259 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 12 May 2012 - 01:56 AM
Great video! LOL :D
#260 nev_payne
nev_payne
  • 2,249 posts
Posted 13 May 2012 - 05:37 PM
Damn it. Oil leaking out of the diff housing, the speedo dropped to nothing after becoming incredibly shakey on an 8 mile fuel run to town and back, the pot joints look toughly half an inch out from the diff housing. That and just discovered the steering rack gater is shredded.. they didn't exactly last long either.
Update: checked the dash speedo connector and that seems fine, managed to pop the flipping rubber grommet out while I was at it :goaway: . Curiously the sound it made when the speedo dropped to nothing seems to be inside the car almost..... one can hope.
Edited by nev_payne, 13 May 2012 - 10:04 PM.
#261 nev_payne
nev_payne
  • 2,249 posts
Posted 15 May 2012 - 10:18 AM
After some consulting I'm under the impression the oil weeping isn't too much of an issue, but it may well be caused by the lower engine stabiliser. Shame really, the engine was rock solid with it in.
The speedo cable has been tested and works fine - it slipped off the back of the speedo clock - had the dash out and it's given me the opportunity of replacing the Volts clock bulb at last.
Typically curious following the parasitic earth problem I decided to wire the fog lights back in. All worked fine.. until the CD Player, Indicators, Interior light and Alarm LED stopped working - all pointing to Fuse C4 / C6 and Fusible link 1. I think my faffing round with the earth point annoyed it.
Going to change that out again tonight and clean up the front wheels as they're off the car. Need to buy some Flash Lemon as well.
Edited by nev_payne, 15 May 2012 - 11:39 AM.
#262 bcjames
bcjames
  • 2,741 posts
Posted 15 May 2012 - 10:39 AM
Flash Lemon?
[Posted Image
lemon-slice-usb by bcjamesmini, on Flickr
So no issues with the diff or speedo drive then? Just the cable at clocks end? That's a relief!
Edited by bcjames, 15 May 2012 - 10:40 AM.
#263 nev_payne
nev_payne
  • 2,249 posts
Posted 15 May 2012 - 11:41 AM
Yeah I've re-organised the cable route as well tso it's much easier to get to... given most of my time was spent wrestling it over the injection manifold. Yup Flash Lemon.. with no bleach for the leather seats. Well overdue in clean prepping for L2B now.
Edited by nev_payne, 15 May 2012 - 11:42 AM.
#264 nev_payne
nev_payne
  • 2,249 posts
Posted 15 May 2012 - 11:11 PM
Update! Found the culprite:
The interior light loom was pressing against the bulkhead from behind squashed by the door stay. Enough squashing ensured a nice short. SirD got a full set of brand new Maxi Fuses and a total check over of all the blade fuses out of it.
Oh...and another dash removal. O_O I think he just likes getting his insides tickled. :whistling:
#265 nev_payne
nev_payne
  • 2,249 posts
Posted 16 May 2012 - 10:44 PM
Update - last time SirD will be without coach lines for a few solar orbits. Off to the body shop tomorrow to have them done properly:
Rear window cappings have come back today as well, matching the depth and texture of the dash. Far better than the sun and water damaged look I sent them off with. Amazing what a good re-lacquer can do.
Edited by nev_payne, 16 May 2012 - 10:45 PM.
#266 nev_payne
nev_payne
  • 2,249 posts
Posted 17 May 2012 - 08:54 PM
Looking good - while I was hoping to have this all wrapped up by lunchtime to start packing for L2B, the body shop got stuck with the length of each stripe and wanted to make sure I would be happy with the outcome. Looks spot on as far as I'm concerned.
Edited by nev_payne, 17 May 2012 - 08:54 PM.
#267 buddylove
buddylove
  • 1,640 posts
  • Local Club: SAMOA
Posted 18 May 2012 - 06:44 PM
Looks great.
#268 nev_payne
nev_payne
  • 2,249 posts
Posted 20 May 2012 - 10:26 AM
Front and centre. Sir D behaved for the most part on the route down.
Edited by nev_payne, 20 May 2012 - 12:08 PM.
#269 bcjames
bcjames
  • 2,741 posts
Posted 20 May 2012 - 06:23 PM
Looks great Oli!!!!
#270 nev_payne
nev_payne
  • 2,249 posts
Posted 21 May 2012 - 11:42 AM
Some nice gold dust I picked up yesterday:
