City E Custom Rebuild
93 replies to this topic
#16 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:34 AM
This week i have stripped and cleaned my SPI inlet and throttle body.
Also today, i have done the brake lines (no pics with them connected) and tidied up the loom.
#17 Jackman
Jackman
  • 4,053 posts
More pics from the engine rebuild
Diff built up
Transfer Gear
Diff in box ;)
Idler Gear
OOOO
Engine pics
Gearbox on
#18 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:35 AM
Done some of the interior. Here are a few pics.
Before
Stripped
Prep
Starting to stick
Final Product
Not too bad, hopfully will go right when its dry.
#19 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:36 AM
Engine Pics ;)
Clutch oil seal going in
In
Clutch going on
Hidden from sight :angel:
Well there it is the engine is built :D
Had to put the rear seats in to make my rear shelf up so decided to put a door card in too :cry:
Also put the headlights on and did the brake lines proper so they are connected
#20 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:38 AM
Wheels Arrived.
Bit over exposed...
Finally put the calipers on
Test fitted the new wheels
Headlining Went in then came out as i am going to trim it first.
Exhaust was cleaned and polished ready.
#21 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:39 AM
Done more stuff, getting ready for the engine now.
Bumpers, foglight, wiper motor and other components in place.
Finishing off the interior.
Here are some pictures ;) :D :angel: (by the way the rocker cover is just one for protection atm)
The engine sitting ready to go in :cry:
Its in ;)
Parts connected up ready :strongsad:
And the exhaust with handprints.
#22 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:40 AM
Well today was a good day... ITS ALIVE... here are the pics and the vid, there was a few problems however.
Everything there
The startup
Bedding the cam in.
Running ;)
MMM need to make the spring shorter i think.
Its upto temp.
Aftermath :D
The engine started first time after getting oil pressure up, this drained two batteries (both dead) but when we went to start the engine, as you saw it just came alive, was such a good feeling to know its working, the oil psi gave a problem, seems to have caused the main galery plug to leak which is why the psi went down after that, we thought it was sorting itself out.
Also it did not idle right as there was a problem with the lambda but in all it was a very good weekend.
#23 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:41 AM
More pictures of the progress, Interior work ;) Also my Fan and Filter arrived.
Windows and Headlining are in, but headlining isnt finished.
Last bits from paint now too.
Now im off work for a week, time to get cracking :D
#24 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:42 AM
Finished the front screen.
Drivers door on.
Rear windows in.
Doors close
Central locking and electric windows
Rear interior
Arches on
Seats in
Dash in.
Yummy ;)
#25 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 10:48 AM
The final product!!
It managed to get to the IMM in denmark but didnt make it back due to fuel over there and blowing the headgasket.
Copenhagan Harbour
DOH!!!
Fixed the headgasket and took it to work for a test drive. On the way home a BMW ran into the back of me... well ill let the pictures do the talking :'( 2 months on the road and this happens.
Its being repaired now, so thats all the pictures i have at the moment, shall update when she is back from the repair shop.
You can now post.
#26 cityspeed
cityspeed
  • 193 posts
Posted 05 February 2008 - 12:07 PM
wow! what a project!, my resto on my city e has had a few twists and turns but i havent found any "roofing felt",,,, well yet! its such a shame that bmw crashed into you! but at least your paint is fresh so matching the colour will be easy, are you tempted to go for a mk1 rear light conversion, as your going to re shape that rear end??? have you dyno'd that engine it would be intersting to see what bhp your running with a spi,
Love your project, its made me go do some more prep on mine!, good luck!
#27 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 12:23 PM
I didnt want mk1 lights as i prefer the mk2 look on it, the car isnt a mk1 style its more mk2 so thats why i went with those lights and the rear reverse lamp.
Not dyno'd the engine yet but shall do when its been run in again as its had new rings after the overheating in denmark.... that reminds me engine diagnostic. Sprocket was the guy who helped me with my engine and very kindly checked the engine over, got that hot it melted the powdercoating and the poly bushes.
The bores had been polished as i didnt drive it hard enough in the first 50 miles ;) but there was other problems.
This is the worse piston skirt damage caused by overheating the side of the pistons are thicker so expand more giving that.
You can see the aluminium in the block (note on the exhaust side)
This is how the other pistons are
Crank is still mint thank god.
You can see in these pictures the difference in the bores, shiny at top
Also there was a few things wrong with the "Rebuilt box" This is what sprocket said.
first off, oil leak suspected on the speedo drive spindle as there was half a gasket still on the flange bit where you screw the cable on, under that there was a full gasket.
second, the lay gear end float clearance is 9 thou!!
thrid, the selector fork bellcrank retaining nut was only screwed on partialy and hand tight, there was another 5mm to tighten it up!!!!!
also suspect there was an oil leak on that bellcrank bush that is located in the sump, you know the bit, its te big round bit on the bottom exterior of the box it was very oily from both sides and full of C**p
one other thing im not happy with and possibly the reason for loss of oil pressure.
im not at all happy with the center oil pick up pipe.
there was a fair amount of C**p on it, the gauze is not the finest ive seen and only half the gauze is actualy open to the oil, the rest is covered by the pipe itsels as the pipe has been cut at an angle, add to that, the open bit is toward the bottom where the crud usualy gathers, idle speeds the pump is finding it difficult pulling the oil through.
purely speculation, but could explain the motorway oil pressure being fine and idle being low.
just not happy with that oil pick up pipe
#28 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 05 February 2008 - 12:30 PM
Oh my god!
What a project and what a shock at the end!! ;) My heart actually sank! :D
Fantastic looking Mini though, Jackman ... Great work :cry:
Hope you're not too disheartened by the stoopid BMW, and that it's all fixed up and OK soon! :angel:
#29 Jackman
Jackman
  • 4,053 posts
Posted 05 February 2008 - 12:31 PM
Nope im not disheartened by it, got another project to start on too, post that up either tomorrow or later.
Just want it back on the road ;)
Edited by Jackman, 05 February 2008 - 12:32 PM.
#30 jonny-b
jonny-b
  • 189 posts
Posted 05 February 2008 - 02:04 PM
That is one fantastic rebuild - but what a let down at the end with the damage.
Hats off to you, you have done a top notch job.
