Paul.
City E Custom Rebuild
#76
Posted 09 April 2009 - 06:40 PM
Paul.
#77
Posted 09 April 2009 - 09:32 PM
Cant wait to see the finished dash.
#78
Posted 10 April 2009 - 12:38 PM
that looks really cool
Edited by Jonnuss, 10 April 2009 - 12:38 PM.
#79
Posted 10 April 2009 - 01:40 PM
#80
Posted 10 April 2009 - 02:58 PM
Where did you get all your elecrikity bits from
Paul.
I got them from vehicle wiring products. A great service.
Dash is coming along... all be it alot slower than i hoped.
#82
Posted 10 April 2009 - 10:05 PM
Nice dash your putting in there. When you inviting me round to come and have a look
#83
Posted 11 April 2009 - 08:41 AM
great project thread , very lucky with getting a new shell . gives a great base to work on . Looks like this mini is going to have a alot of love and money put into it over its life - great to see
Hello Edd
How's you're shell getting on with the spray??
Dash looking good Chris
#85
Posted 11 April 2009 - 05:14 PM
#86
Posted 12 April 2009 - 08:37 AM
and your dash is the mutts nuts good work
YetI
#87
Posted 12 April 2009 - 05:27 PM
Im getting there.
Dash has been working, all the lights, fuel gauge, volts, rev counter works and speedo has been turned on.
Few wiring faults.... Nothing serious, just few silly things like should have been a constant live instead of a switched on the brake warning light, need to wrap a few wires and re-do a few connections which i broke.
Plans for tomorrow is to fit the speed sensor and get that calibrated and then fix a blocked breather
Wires are alot tidier than they were.
Some more to tidy
Old connector
Wires
Connections
Nearly in... needs tidying.
#88
Posted 13 April 2009 - 06:42 PM
Speed Pickup
4 nuts glued on the hub... later took off as it hit the cylinder, replaced with weld on the back of the studs.
Dash in.
Volt, oil and fuel
Speedo, water temp, vac and rev
Completed
Love it. Next steering wheel.
Edit.
Forgot to mention, need to sort my charge light, the resistance is higher than the old bulb so takes more revs to start the alternator working.
Also replaced my gearstick... if i went to find reverse it would engage and then it could spin around 180 degrees.... dont know why or how it did it but new stick fixed that.
Edited by Jackman, 13 April 2009 - 06:45 PM.
#89
Posted 13 April 2009 - 06:54 PM
#90
Posted 14 April 2009 - 07:17 AM
Noticed another thing with a working temp gauge... it doesnt go above 70... no wonder its drinking fuel
