How Much Is This Topic Worth?
10076 replies to this topic
#1591 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 09 April 2008 - 11:30 PM
LOL I tried all that to start with :( And the elbow grease set me right back!
The piston is moving up and down nicely, I thought it could have been that, So cleaned it all up, and rubbed it over with some emmery cloth to smooth it?
I thought maybe an air leak?
are you talking about mini's now or is this some strange kind of humour
forgive me, as im not quite sure
>_< emery cloth is way too abrasive ! do you have a polishing wheel to buff it up ?
;) this is one of the more sensible moments - dont worry, it'll pass fairly quickly and we'll degenerate into something fairly stoopid.
Edited by roofless, 09 April 2008 - 11:31 PM.
#1592 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Ah sssshh-it. You joking? It was only light! I did the inside of the dash pot..And the piston a bit...
Nope, sorry!!
What oil are you using in the dashpot?
#1593 bloomers
bloomers
  • 815 posts
Posted 09 April 2008 - 11:32 PM
Erm the stuff its always used, Cant remember I think its some castrol stuff.
I wasn't emery cloth. It was wet and dry..like 1500-2000
#1594 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 09 April 2008 - 11:36 PM
Ok then, if the piston rises and falls freely(i use 2 stroke oil in the dashpot)
Are there any leaks in the vacuum pipes?
And insulting your intelligence!!! Is the throttle cable sticking?
Have you pulled a plug out to see how shes running?
Failing that how about an insurance job?
#1595 bloomers
bloomers
  • 815 posts
Posted 09 April 2008 - 11:40 PM
Currently it doesn't have a vacuum advance on it... Problem? Insurance...It doens't have any atm! As its not on the road.
Throttle cable is all sweet..And its firing good as its revving high! Just so you get an idea of high...I have a straight through 2" system, and its so loud it blew the bulb in my garage...I think its reving near 3-4K LOL
#1596 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 09 April 2008 - 11:41 PM
You've clearly ruined the mini now ! I'll give to 100 quid for it :(
>_< dont panic ! its probably an easy fix - shifty's right though, check that your cable isnt binding, and your pedal assy - and even the butterfly on the carb. may just be the remainder of the cable fouling on the butterfly mechanism perhaps ?
#1597 bloomers
bloomers
  • 815 posts
Posted 09 April 2008 - 11:48 PM
Hmm, Checked the fouling issues. How much should the idle screw be down sort of on average?
Ahhh this problem is driving me mad!
#1598 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Anyway what the hell does this sound like a tech forum?
Have you read the last 100 odd pages?
Do we really sound like we know what we are on about?
Disconnect all the cables any try it?
One question I haven't asked, did it do it before you changed the needle?
Edited by shiftyseamus, 09 April 2008 - 11:49 PM.
#1599 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 09 April 2008 - 11:52 PM
wow - the beer must be wearing off !
quick, quick - something dumb ! we have a reputation to maintain !!!!
I think there may be a problem with the cat on my MPI - I've tried everything but to no avail - I have video'd the problems - see what you reckon..............
b11R7wiaTvU
#1600 bloomers
bloomers
  • 815 posts
Posted 09 April 2008 - 11:53 PM
Yea did the same before needle change...Which is originally why i changed it, as i thought it was dropping due to a lack in fuel...thus changed to a AAU...
LOL, Yea sorry for the thread Hi-Jack here >_< Just Piccing me off to no end now!
I have tried disconecting everything but the go pedal goes right to the floor??:(
#1601 supastu
supastu
  • 242 posts
  • Local Club: not in one yet
Posted 09 April 2008 - 11:55 PM
just a quickie and been as your married you must have some experience. do you know any good chat up lines
#1602 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 09 April 2008 - 11:56 PM
Ok then, its def the carb(probably), it may be better to swap it for another one?
I think if you carry on you may end up beating your head against the proverbial wall!!
Cheap enough as well!!
#1603 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 09 April 2008 - 11:57 PM
LOADS
what speaks french, has 2 thumbs and likes b-jobs?
#1604 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 09 April 2008 - 11:58 PM
LOADS
Pardon? je ne pense pas queque tu parle ? >_<
#1605 bloomers
bloomers
  • 815 posts
Posted 10 April 2008 - 12:00 AM
I know a good one....Get ya rat out luvvy!
Cheers boss >_< might try a rebuild of this one :( I will have a try tomorrow
