My Mini ;) The First Chapter.
#991
Posted 05 April 2009 - 10:06 PM
let me know if you get an ASBO =)
#992
Posted 06 April 2009 - 09:04 AM
Right I've been thinking about getting the front sprayed up & everything sorted, for example the holes cut, lights mounted, numberplate on etc..
1) what is it best to cut the holes with?
2) I'm going to spray the whole thing in grey primer, can I just spray straight on? do I need 2 coats?
#993
Posted 06 April 2009 - 10:06 AM
I was told to trim the excess lip with a diamond tile disk (without the slots)
#994
Posted 06 April 2009 - 11:19 AM
I'm going to use one of those and then use a file to finish the holes off. Then again, I've only got my indicators to do
Have you not thought about waiting until the front is all fitted to the car before doing that? I keep getting tempted but I want it on the car before i start fitting lights and stuff, just to make sure everything is a-ok.
#995
Posted 06 April 2009 - 02:19 PM
Grille isn't a problem because there is a line I can work to & the indicators don't seem to hard because it's a small circle so it's easy to judge the center, but on the headlights there isn't a defined line.. ahh, I'll cut out a circle of paper the right diameter and line that up, plan.
#996
Posted 06 April 2009 - 06:36 PM
#997
Posted 06 April 2009 - 08:12 PM
Tomorrow I'll try and split the engine from the subby again, have another go at removing the steering rack.
#998
Posted 07 April 2009 - 02:51 PM
Kinda loosing motivation the more and more I pull it apart.. I'm just getting further away from completion, especially with no money it's doesn't feel like a hobby anymore, just a chore.. I'm sure things will pick up soon enough, but for now it's not fun.
#999
Posted 07 April 2009 - 03:15 PM
#1000
Posted 07 April 2009 - 03:17 PM
#1001
Posted 07 April 2009 - 03:53 PM
gonna rip kevs engine out next week as he wants to cure the oil leaks
i recon hes mad but i already know that hahahaha
#1002
Posted 07 April 2009 - 07:12 PM
After a while it came back and now I'm getting on with it I'm finding that putting bits back is far more rewarding than taking bits off. If you just get stuck in as soon as you can I think you'll find it really enjoyable
Don't lose the faith!
#1003
Posted 07 April 2009 - 08:37 PM
I ALSO WOULD LIKE SOME INFO ON CHEMICAL DIPPING OF THE BODY AND WHERE DOES THIS. THANKS AGAIN CHAPS.
#1004
Posted 08 April 2009 - 07:27 PM
If you want to find out things like that, you should start your own project thread, rather than just hijack someone elses.
And it also helps if you STOP WRITING IN CAPITALS
keep going luke, don't stop now!!
Edited by 1275 SPRITE, 08 April 2009 - 07:33 PM.
#1005
Posted 09 April 2009 - 12:56 PM
Making more progress today! was supposed to be going on a pub crawl bike ride with the lads but the weather isn't the best, so instead I'm outside getting more done
This afternoons task is removing the rear subby, I've come in for some food whilst the nuts soak in WD40, got a bad feeling that it's going to be a pain in the arse to remove.. we'll see
