My Mini ;) The First Chapter.
1498 replies to this topic
#1456 carboy001
carboy001
  • 1,065 posts
Posted 15 August 2009 - 11:36 PM
Id still get the lower dash rail cover put in as you wont be able to spot any blemishes whereas i expect it would be quite hard to get the rail looking perfectly smooth with just paint.
Noticed you had your dash liner set up in the classifieds..........why? :D
#1457 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 16 August 2009 - 07:14 PM
Thanks again for today Luke, had a great day, and please thank your dad again for me please :lol:
James.
#1458 analogue_radio
analogue_radio
  • 4,897 posts
Posted 16 August 2009 - 09:19 PM
Complete change of plan, look a few pages back and you'll see the dashboard I'm going to make, It'll save me some pennies and because I'm swapping to an earlier Switch panel I will loose some switches, need somewhere for these to go so I'll have some toggle switches in the new flat dash.
James.
No worries James ;) it was a good day!
#1459 carboy001
carboy001
  • 1,065 posts
Posted 16 August 2009 - 09:25 PM
Hmmmm I think you should still stick with the original centre binnacle idea and put in a centre console and wack some toggle switches in there ;) your decision though :lol:
#1460 analogue_radio
analogue_radio
  • 4,897 posts
Posted 16 August 2009 - 09:55 PM
Don't worry it'll all come together soon =]
Just uploading all my photos now.
Had a fantastic day at MITP with my Dad & James, bloke who was supposed to be selling me a rear roll cage with a fixed diagonal is a *melon*! name and shame, dave-r5, turns out even though we'd agreed on a price and agreed to meet he sold to someone else for higher.
I guess on the plus side it gave me some extra money to spend at the show :D so I picked up a turbo clutch plate, cam followers, oil pump, gearbox gasket set, oil switch & water temp switch! which means I can hopefully (if I haven't forgotten anything) get the engine put back together :lol:
I'll put a few photos up here of some inspirational photos, absolutely buzzing with some of the things I've seen today.
Check back shortly ;)
#1461 TheBIGGERimage
TheBIGGERimage
  • 47 posts
Posted 17 August 2009 - 07:39 AM
Thanks again for today Luke, had a great day, and please thank your dad again for me please :-
James.
You are very welcome James, it was a great day, I thoroughly enjoyed it and it was really nice to have your company :D
#1462 analogue_radio
analogue_radio
  • 4,897 posts
Posted 17 August 2009 - 09:39 AM
Some of my inspirational photos from MITP (09)
Edited by analogue_radio, 17 August 2009 - 09:40 AM.
#1463 jaydee
jaydee
  • 8,565 posts
Posted 17 August 2009 - 10:30 AM
I have to send you a pic of my old Mk1. It was beige.
#1464 analogue_radio
analogue_radio
  • 4,897 posts
Posted 17 August 2009 - 11:12 AM
Wouldn't mind that :D
I'm going out now to rebuild the clutch.
#1465 carboy001
carboy001
  • 1,065 posts
Posted 17 August 2009 - 11:21 AM
You need to well document the clutch rebuild so I can follow your guide :D
#1466 analogue_radio
analogue_radio
  • 4,897 posts
Posted 17 August 2009 - 01:40 PM
It's really straight forward Carboy!
I've been out & fitted the two new switches, oil pump & replaced my clutch with a turbo clutch, much more lighter when I was holding them both.
Water temp switch.
Oil switch.
Oil pump.
Clutch assembly apart.
Comparison of the two.
Old clutch, well worn!
New clutch, really glad I've replaced it!
Brushed off all the dust, did this outside.. don't worry, nasty stuff.
Back together and finger tightened, then put back on the crank, this makes sure everything is centralised before tightening fully.
Job done! hopefully when funds can afford I might be able to slide a cheeky lightened flywheel in there.
Now I need to learn about Cam followers and replace though so I can then put everything back together.
:D
#1467 sharps555
sharps555
  • 152 posts
Posted 17 August 2009 - 05:12 PM
ive been reading your post on this but by the time i got to the 20 or so page i gave up but look how much you have got done! didnt know you where going stripp her down though :P and im so gutted i coudnt go to the mitp was sooo looking forward to it ;D kinda overlooked a family weekend away when organising it :) was it a good day?
alex
#1468 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 17 August 2009 - 05:38 PM
You are very welcome James, it was a great day, I thoroughly enjoyed it and it was really nice to have your company ;D
Thanks, I really enjoyed it too, and it will be interesting to see which cars are being driven to the show this time next year! Hopefully all 3 :) (well, 4 if you count the one you are going to win in the raffle)
#1469 carboy001
carboy001
  • 1,065 posts
Posted 17 August 2009 - 06:12 PM
Your just saying that because you forgot arent you :P
Told you you were better off changing the clutch now! ;D
Some nice little new bits on the engine make the world of different don't they! Looks tasty. Another few items to add to my list then :)
#1470 MiniLuke
MiniLuke
  • 1,205 posts
Posted 17 August 2009 - 06:42 PM
Received this in the post today from GM, It's a MK2 switch panel.
Fits quite comfortably, will get the two screw holes welded over and smoothed so it looks factory.
& something needs to be done with a tiny gap at the bottom, it's not really noticeable.. but it'd bug me that it was there.
Considering fitting an ignition switch to the centre switch as a toggle, any information on this? how would I go about wiring it?
Looks good ;D
Hi, I have the following pics for you.
I have used custom brackets which are basically very short versions of the originals (originals in the photo).
You are very welcome to these brackets if you want them, but they do hold the switch panel out too far unless you use the padded rail.
Like you say, there is a gap underneath the panel and the screw heads show but I still quite like it.
Cheers, Luke
