The red oxide I've applied in places is just applied over the original paint with no prep so the chances it's stuck properly are very slim. I'd rather so the extra work and be sure my paint job is stuck onwould seem like a good rust prevention layer to have underneath the primer & paint.
I would have thought this too.
My Mini ;) The First Chapter.
#1441
Posted 12 August 2009 - 10:00 AM
#1442
Posted 12 August 2009 - 05:57 PM
Also secured a rear roll cage with a diagonal from a chap off here, picking it up at MITP
#1443
Posted 12 August 2009 - 10:14 PM
Dan, James, MITP?
I'll be going...
Got to take a turbo that I sold to someone for him to collect and also I'm picking up my new head
#1444
Posted 12 August 2009 - 10:18 PM
#1445
Posted 12 August 2009 - 10:21 PM
Do you want a lift mate?
That would be great luke, thanks! What time were you thinking of leaving?
#1446
Posted 12 August 2009 - 10:25 PM
We'll be heading out your way? from Long Clawson/Melton way to get to MITP? If I remember last time we passed through your village.
#1447
Posted 12 August 2009 - 10:36 PM
Yeah on the B6047 past the old airfield for about 7 miles to Twyford. Then on the same road untill you get to the texaco and McD on the roundabout, then turn left. I think thats the best way
#1448
Posted 12 August 2009 - 10:42 PM
#1449
Posted 13 August 2009 - 07:29 AM
I've no idea yet! I'm picking a roll cage up and the bloke said he'd be there pretty early, I'll speak with Dad tomorrow and let you know.
Hi both
Say 8.30, then should be there circa 10.00, OK? Where shall we pick you up?
#1450
Posted 15 August 2009 - 07:33 PM
Fits quite comfortably, will get the two screw holes welded over and smoothed so it looks factory.
& something needs to be done with a tiny gap at the bottom, it's not really noticeable.. but it'd bug me that it was there.
Considering fitting an ignition switch to the centre switch as a toggle, any information on this? how would I go about wiring it?
Looks good
#1451
Posted 15 August 2009 - 07:58 PM
How does it fasten? seeing as you dont have those strange brackets the previous switch panel had...
#1452
Posted 15 August 2009 - 08:07 PM
It's also been pointed out to me that the switches are the wrong way round
Hopefully be coming back from MITP with some bits and pieces
#1453
Posted 15 August 2009 - 08:39 PM
I'm sure thats how it is and it doesnt sit flush, my one is mounted like that I think.
Edited by GreaseMonkey, 15 August 2009 - 08:40 PM.
#1454
Posted 15 August 2009 - 08:53 PM
#1455
Posted 15 August 2009 - 09:00 PM
Them brackets need to fit in on the sides to support the cables I think so maybe you could chop the brackets about and weld them after some head scratching so it makes the panel sit flush?
