Bungles Cooper
#61
Posted 18 December 2008 - 02:44 PM
buy only 1 follower out of 8
so i can't see it's a rocker problem
#63
Posted 18 December 2008 - 03:46 PM
#64
Posted 18 December 2008 - 03:59 PM
Odd that so much damage has been done, I can see Graham's reasoning behind the valve-train wear, but what about the drop gears (which is what probably screwed up the bottom end).
#65
Posted 18 December 2008 - 04:19 PM
#66
Posted 18 December 2008 - 04:20 PM
Read down this page Same damage as your cam using 1.5's
mine had much more damage but only on 1 lobe
if you look at my topic in the technical section i think Dan comes up with the most likely reason, can follower got stuck and would not spin
#67
Posted 18 December 2008 - 04:24 PM
So what the new engine spec then?
it's now a 1330 with minispares high torque cam
using my stage 3 minisport head, HIF44 with K&N filter and single box RC40 with maniflow LCB
not big power but a very drivable engine
speaking to Simon this cam works with the 1.5 rockers ok so i will keep them
#68
Posted 18 December 2008 - 05:02 PM
Either of those 2 failures would've been hard on the oil 'n could've got the other started. Maybe the valve first as it seizing would create more load on the tranny gears when on overrun but the gear going awol wouldn't load the valve.
#69
Posted 19 December 2008 - 09:48 AM
#70
Posted 19 December 2008 - 01:56 PM
but remember this is my second gear box, the first one the diff went bang and could of caused some damage
that was about 18-20k miles ago and the oil pump was replaced but engine was not striped
#71
Posted 26 December 2008 - 05:01 PM
removed the 4 way and 4 separate fuses and replaced with a new 12 way board (extra ways are for central locking, spot lights etc
#72
Posted 27 December 2008 - 05:15 PM
Mick
#73
Posted 27 December 2008 - 05:26 PM
#74
Posted 27 December 2008 - 07:34 PM
#75
Posted 11 January 2009 - 09:51 PM
vehicle wiring products
is nexted sunday ok for your engine bungle, i should be able to fit you in then
