Can you tell me if the is a spacer between the rocker and the top of the shocker, and is it one long Bolt to go
through.
Thanks bendion58.
2008 Hayabusa Mk1 Race Spec - A California Car :-)
mgecko1
, Jul 02 2008 02:45 AM
64 replies to this topic
#61
Posted 18 June 2010 - 04:35 PM
#62
Posted 18 June 2010 - 08:05 PM
through.
Thanks bendion58.
yeh the long bolt should get fitted from the front of the car and the nut goes towards the rear of the car incase you need to take the bolt out again as if you put it in the other way the bulkhead will get in the way,
the answer to your question is that the thick spacer around 12mm goes between the rocker and the steel bracket on the sub frame
Ed
#63
Posted 18 June 2010 - 08:30 PM
Thanks Ed
that solves another problem.
Regards Ben.
Regards Ben.
#64
Posted 18 June 2010 - 08:37 PM
Some one needs to do a MK1 sleeper
looks just like a standerd MK1 but with something tasty hidden away
#65
Posted 18 June 2010 - 09:50 PM
Thanks Ed
Regards Ben.
just pm me for any build queries, and i will try my best to post pictures or give advice
Ed
Edited by edsmini, 18 June 2010 - 09:53 PM.
