Oh Dear, Suspensions Gone Wrong...keeps Dropping No What I Do...please Help!
Posted 26 July 2008 - 04:00 PM
The problem - Drivers side front suspension keeps dropping
Caused by a small bump, into another car. subframe appears fine as the distance from the cente of the rear wheel to the front are pretty much the same for both sides.
What Ive done: New rubber cone as old 1 was deformed
Trumpets fine
oil\air shock is fine
Upper suspension arms fine.
After doing the work and taking it off the jack and not putting any additional load onto the car I could easily get a fist clearence between the arch and the wheel. After loading with a short drive with 2 people can only get a 3 to 4 fingers width gap.
Really gutted. Please help. I can have it jacked up and get any photos \ compare sides to help woth your responses.
Eagerly awaiting your replies,
Karl & poorly Phoebe!
Posted 26 July 2008 - 04:09 PM
Posted 26 July 2008 - 04:19 PM
I have standard suspension
Posted 26 July 2008 - 05:43 PM
Posted 26 July 2008 - 06:07 PM
i may have some spare suspension bits in the shed if you need them, I'm not sure what they are like but your welcome to them if your desperate, im sure i have some top arms.
and I'm not too far from you
take it all apart, well the wheel off at least, and see what you find, lets go from there
Posted 26 July 2008 - 06:22 PM
it look to me as if somethings damaged somewhere, may even be the part of the top arm that the knuckle sits in.
Thanks Anorak, you came to my house once for some bits?
I have had the arm out and the knuckle cup replaced along with the new cone.
Posted 26 July 2008 - 06:48 PM
take the wheel off and take some pics of the top arm, shock etc.
lets see if we can spot anything wrong
Posted 26 July 2008 - 07:06 PM
Posted 26 July 2008 - 08:50 PM
Check the subframe turret mounting rubber. check the clearance between the top arm and bumpstop to determine if the fault is with the cone or trumpet. You should really replace rubber cones in pairs cones.
The cone I didnt replace is about 2 months old....I put 2 new cones in a while ago. Im a student got to economise lol
Ive got a hunch.... could height loss be caused by subframe mounting point....will attach a comparision pic....
Annorack will get pic 2moro lot of effort to get wheel off in dark
thanks all
Posted 26 July 2008 - 09:02 PM
Posted 26 July 2008 - 09:05 PM
It could be down to settling as mine went down from being able to get a fist in the gap to being able to just get one finger in the gap...
sinking straight away a load is applied and after a lil bump....to good to be true. think theres the devils work at play not sinking! lol
Does anyone know what colour wire is sidelight +ve for a 1989 Mini city E?
Posted 26 July 2008 - 10:46 PM
Pic of dodgy side
Posted 26 July 2008 - 10:48 PM
Posted 27 July 2008 - 06:54 AM
Rob
Edited by DaveRob, 27 July 2008 - 06:55 AM.
Posted 27 July 2008 - 11:10 AM
Buy genuine every time, if they dont say dunlop or Moulton on them, dont by them!!
