I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
919 replies to this topic
#16 nicklouse
  • 19,067 posts
Posted 01 October 2014 - 04:45 PM
postie has been.
Attached File  IMG_0392.JPG   88.71K   14 downloads
#17 nicklouse
  • 19,067 posts
Posted 02 October 2014 - 05:44 PM
Attached File  IMG_0782.JPG   61.84K   37 downloads
mm slightly different. i wonder how it will effect things.
long weekend so might have it running.
#18 nicklouse
  • 19,067 posts
Posted 03 October 2014 - 02:51 PM
all together.
#19 nicklouse
  • 19,067 posts
Posted 09 October 2014 - 09:39 PM
Mmm I am thinking that a full strip down is on the cards.
A bit more rust than I was hoping.
As it runs and I have no real date to have it running I may as well do it right.
#20 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 10 October 2014 - 09:31 AM
great project! show us more!
#21 nicklouse
  • 19,067 posts
Posted 12 October 2014 - 07:51 PM
not much happening this weekend. too much motorsport to watch on TV.
but removed the tin work
Attached File  10469093_10152556368578171_7511318193405928720_n.jpg   37.18K   71 downloads
the tin worm has bee active. need a pair of sills.
but before that. needs engine out subframes off and somehow supporting. time to get fabricating.
#22 nicklouse
  • 19,067 posts
Posted 13 October 2014 - 07:22 PM
May as well list the spec as best as I can.
1293cc
Weber 48IDA with a unmolested original manifold.
Head. Mmm can't remember but big valves and big valves.
Kent 296 scatter cam.
1:1.5 full roller rockers
Electronic ish ignition.
Alloy flywheel with steel friction face. Lightened steel back plate. Grey spring, standard plate.
SC drops I think 1:1.1
Remote box.
Jack Knight cam and pawl LSD 1:4.3 final drive I think.
Remote oil filter, early front mount Mini rad.
Suspension all rose jointed. Including steering. Mini spare alloy 4 pots grooved solid discs.
Rear metro arms on a custom beam to give a wider track. Super mini fins.
Wheels revolution 13" 4 spokes. 9" front 8" rear.
Tyres 8.2 front 7.0 rear 20" diameter. (Rears might be 7.2")
Fiberglass where allowed. Laminated screen and Perspex.Log booked Mod prod hill climb car.
Work to do:
Engine changes to do. Electric water pump. Re locate filter.
Body work. Sills and underbody work.
paint.
Edited by nicklouse, 13 October 2014 - 07:23 PM.
#23 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 13 October 2014 - 07:38 PM
That sounds immense!!
#24 nicklouse
  • 19,067 posts
Posted 13 October 2014 - 07:58 PM
Oh forgot the shocks.
AVO coil overs rear. Spax coil overs front.
#25 pinkmini99
pinkmini99
  • 563 posts
Posted 14 October 2014 - 02:00 AM
Hi there just a quick question what bh p was she running ?
#26 nicklouse
  • 19,067 posts
Posted 14 October 2014 - 08:21 AM
very good question. when it was on the rollers they said it was a very good 1380 motor.
I then told them thanks but it is a 1293.
as to figures I don't really use them as it was often used by tuners to get more customers. I just looked at did a change get more numbers on the same RR.
1/4 mile times of 15.01 maxing out on the revs and a windscreen covered in fuel. change the gearing and it would go faster but not what the build was for.
#27 nicklouse
  • 19,067 posts
Posted 15 October 2014 - 07:25 PM
Attached File  roll.jpg   58.73K   53 downloads
starting to sort out the arch shapes.
#28 nicklouse
  • 19,067 posts
Posted 18 October 2014 - 06:28 PM
today involved lots of Tea
Attached File  1891217_10152569825348171_1360432135833843234_n.jpg   38.77K   26 downloads
Attached File  1013246_10152569825408171_8686589264244992701_n.jpg   51.11K   31 downloads
Attached File  1794664_10152569825448171_8210652369770234081_n.jpg   44.71K   32 downloads
Attached File  10632606_10152569883973171_7806172807794039118_n.jpg   44.31K   53 downloads
now it is Beer O`clock
#29 nicklouse
  • 19,067 posts
Posted 19 October 2014 - 06:53 PM
today as i left the apartment i saw some old carpet by the bins. sorted.
jut so i know which way they go.
Attached File  1924717_10152571783998171_2117555419996909714_n.jpg   74.35K   80 downloads
mm these dont look right.
Attached File  1382126_10152571784083171_2822959551524855178_n.jpg   40.42K   70 downloads
Attached File  65555_10152571784148171_6623073355150437581_n.jpg   42.57K   39 downloads
old skool solid rear front subframe mounts.
Attached File  1959410_10152571784198171_8599118875737262108_n.jpg   54.9K   51 downloads
subframe cleaned ready for seam welding.
Attached File  10346535_10152571784328171_7553904999500233070_n.jpg   52.98K   56 downloads
70s?
#30 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 19 October 2014 - 07:12 PM
Nice garage carpet! Looking good
    Bing (1)
