Mini 25 Engine Rebuild
roundnose
20 replies to this topic
#1 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 18 July 2015 - 01:20 AM
Preparing the Work Space
I have been able to steal some work space in my friends work shop to help remove a broken engine from a Mini 25 and strip down and rebuild. The engine would require a full rebuild therefore I have been able to steal it to help improve my knowledge. Don't worry, The Mini 25 will be getting a new engine and the gearbox will be taken and re-used.
Mini%2025%20Engine%20Rebuild%202_zpsij3h
Removal of the Engine
The car was placed in the correct position within the workshop to allow access to the whole car with reasonable movement and adequate space. The wheel nuts on the front of the car were loosened before jacking the car up. A hydraulic jack was used and the axle stands were placed under the car to secure and chocks were used to secure the back wheels. The handbrake was also put on the ensure that the car was secure and safe to work on. The wheel nuts were then undone and the two front wheels removed from the car.
Mini%2025%20Engine%20Rebuild%201_zpski5m
Using a ratchet with a 9/16 socket the brake calipers were removed and using a cable tie fastened to the tie rod to prevent damage. The ball joint retaining nuts were undone and using a ball joint splitter the ball joint tapers were broken, the shocker absorbers were removed, of which one nut was rusted and took me over 20 minutes to remove, as well as the removal of the assembly and drive shaft.
Mini%2025%20Engine%20Rebuild%204_zpsfnby
Mini%2025%20Engine%20Rebuild%205_zpsxwd4
The exhaust was then removed from the manifold by removing the exhaust mounts located on the back on the rear subframe. The inlet manifold and carburetor were then removed as well as the exhaust manifold.
Mini%2025%20Engine%20Rebuild%206_zps4rpt
Reason for the replacement Engine:
Mini%2025%20Engine%20Rebuild%207_zpscitm
The block is damaged due to the head gasket blowing. When we removed the rocker cover it revealed a substance on the cam shaft and cylinder head. This was caused by the oil and water mixing when the head gasket blew. Finally we disconnected the fuel line and used a engine crane to remove the engine.
Mini%2025%20Engine%20Rebuild%209_zpsuwoc
Mini%2025%20Engine%20Rebuild%2011_zpswfs
The Engine Bay will be tidied up and re-painted. A replacement engine has been purchased to put back in and the original engine will be stripped down and cleaned up. I will make another Topic Feed to document the Engine Strip as well as putting the new engine in  :proud:
Mini%2025%20Engine%20Rebuild%203_zpstm7w
Edited by Miss.S.L.Hope, 03 August 2016 - 11:58 PM.
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 18 July 2015 - 06:11 AM
Get yourself a box of nitrile gloves
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 July 2015 - 09:05 AM
Or a tub of Manista.
Looking forward to this thread. You have my attention :-)
Ben
#4 malcs_miniturbo
malcs_miniturbo
  • 602 posts
Posted 19 July 2015 - 06:52 AM
Yes il be also watching this and looks nice work shop have
#5 MrBounce
MrBounce
  • 2,688 posts
Posted 19 July 2015 - 01:56 PM
+1 on either gloves or the Manista. And the fact it's a 25. :thumbsup:
#6 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 22 July 2015 - 01:32 AM
Mini 25 Engine Rebuild - Continued.
The engine has now been removed and will be strip down ready to take the required parts and clean up the original engine. The Engine was removed from the Engine Crane and placed onto a Engine Trolley.
Mini%20Engine%20Rebuild%20-%20Reply%201_
The Engine was then dismantled to allow the engine internals to be stripped. These were all laid out on the work bench I had been given to be photographed so I could label each part to help improve my knowledge.
Mini%20Engine%20Rebuild%20-%20Reply%202_
Mini%20Engine%20Rebuild%20-%20Reply%203_
Mini%20Engine%20Rebuild%20-%20Reply%204_
Short Block and the Gearbox. The Gearbox will be going back into the car and the shortblock will be stripped down.
Mini%20Engine%20Rebuild%20-%20Reply%205_
Also managed to take a photo of me getting filthy!
Mini%20Engine%20Rebuild%20-%20Reply%207_
Stripping down of the short block (Engine Internals)
Mini%20Engine%20Rebuild%20-%20Reply%208_
The pistons were removed as well as the crankshaft.
Mini%20Engine%20Rebuild%20-%20Reply%209_
Mini%20Engine%20Rebuild%20-%20Reply%2010
The engine is now ready to be cleaned and the replacement will be put in when we have a few more parts  :proud: . Apologies this is a bit brief. I will go back and edit to add more detail at a later date! It is now the early hours of the morning and I'm exhausted! I will also add the documentation that I created that labelled all the parts.
Thanks Guys :D.
Edited by Miss.S.L.Hope, 04 August 2016 - 12:02 AM.
#7 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 22 July 2015 - 05:41 AM
Some top work there, whats the plans with the engine just clean and refit etc or you building a monster? Nice to see a Women getting stuck in :)
#8 Zeemax Adventure
Zeemax Adventure
  • Just Joined
  • 301 posts
Posted 22 July 2015 - 02:53 PM
Im keen on this..... A detailed step by step with pics :)  Oh and good on you for getting your hands dirty...more people should try it!!!!
#9 Steve8274
Steve8274
  • 580 posts
Posted 22 July 2015 - 09:00 PM
Good progress. Well done
#10 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 22 July 2015 - 09:06 PM
Hah, this is about 10000% more organized than I am!
Good luck, if you need any random 998 bits, i've got quite a lot off of an old 998 I stripped down.
#11 mk1leg
mk1leg
  • 9,343 posts
Posted 22 July 2015 - 09:08 PM
I hope you numbered the pistons as you took them out.........
#12 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 22 July 2015 - 11:13 PM
Pistons Numbered & Marked orientation of the caps 👌.
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 July 2015 - 11:14 PM
Pistons Numbered & Marked orientation of the caps .
whoops, i didn't when i stripped mine  :shy:
#14 Stu.
Stu.
  • 912 posts
Posted 24 July 2015 - 07:52 PM
Probably be ok if your renewing the bearings, pistons & rings and reboring Ben.
Great work so far. Looking forward to more ......
#15 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 25 July 2015 - 11:09 PM
I might have just bought a VW Golf GTI 1.8 16V that needs a little work. So will be splitting my time between the two. Will hopefully be cleaning up the engine tomorrow and starting to rebuild as well as doing some work on the Golf. Will keep you updated 😁.
