And I’m guessing I’ll see you at the nationals in October?Not sure if you know or not, you are able to reregister the car and reuse the original plate.
Steve from Classic mini spares in Te puke told me.
Beats changing to a new one.
Yeah, got that teed up already, so ill be keeping the black plates. Wouldve been pretty disappointed if i had to change to white ones.
#61
Posted 10 July 2018 - 11:45 AM
#62
Posted 10 July 2018 - 08:35 PM
Not sure yet. Maybe, since its in my neck of the woods.
#63
Posted 11 July 2018 - 03:54 AM
Yeah, that was my way of thinking also.
#64
Posted 12 July 2018 - 10:38 AM
#65
Posted 12 July 2018 - 11:38 AM
#66
Posted 12 July 2018 - 11:54 AM
Just a thought with reference to the tie rod nut & bolt - would it not be better to put the bolt in from the bottom and the nut at the top, to avoid the clearance issue???
#67
Posted 12 July 2018 - 12:13 PM
#68
Posted 12 July 2018 - 12:14 PM
I did this originally as a quick fix, but figured there must be a reason its fitted from the top down. Only thing i can think of is that if the nut comes loose the bolt could fall out and then its game over?
#69
Posted 12 July 2018 - 09:04 PM
Yep, it’s a good failsafe to have the bolt through from the top. If it did come out you’d be screwed..
#70
Posted 13 July 2018 - 07:12 AM
I've also had the lower arm bolt come undone during an emergency stop. Also not fun...
#71
Posted 28 July 2018 - 03:33 AM
#72
#73
Posted 12 October 2018 - 07:00 AM
Its been a while, but I finally got around to taking the Mini down for its re-registration inspection so that it can be driven on the road again.
Unfortunately the inspection was a fail,
So I need to sort these,
A new lower ball joint (will do the pair)
A new rackend, which isnt available, so a new steering rack ![]()
Rebuild both rear radius arms
Replace both rear shocks (apparently there is play before the cones compress)
And fix the brake imbalance (LH 10% / RH 93% - Almost nothing from the left), which may be the hard one to do. I don't recall any obvious leaking etc when i last removed the drums, so will strip both down, clean the lot, and replace the rear hoses when I remove the arms. Hopefully there is something obvious that needs to be replaced.
I'm not looking forward to the work, and only have 20 working days to sort it all before i have to pay again and have a full inspection.
#74
Posted 12 October 2018 - 07:38 AM
Why can’t you get a rack end?Its been a while, but I finally got around to taking the Mini down for its re-registration inspection so that it can be driven on the road again.
Projects →
Mini Saloons →
1976 Mini 1000 Le "stripey"Started by cafeclassic , 03 Sep 2025 |
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 |
Bing (1)
