Getting The Rose Family Mini Back On The Road! (After 5 Years)
roundnose
297 replies to this topic
#31 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 18 June 2019 - 01:16 PM
Best of luck!
Lots of labels and sealed plastic bags for storage help, and photo's of anything tricky (before you remove it).
Anything that comes off and has the ability for the screw/nut/bolt to go back in the same part that you've removed, makes it easier when you come back to it - or when you're refurbishing batches of bits.
#32 ryomini
ryomini
  • 583 posts
Posted 18 June 2019 - 01:31 PM
Time for the welding skills
#33 Ben Rose
Ben Rose
  • 210 posts
Posted 18 June 2019 - 04:44 PM
Do I have welding skills? Awesome, I didn't realise I had
any. ?
Edited by Ben Rose, 18 June 2019 - 04:44 PM.
#34 Ben Rose
Ben Rose
  • 210 posts
Posted 18 June 2019 - 04:45 PM
Best of luck!
Thanks, V.Good advice.
#35 Ben Rose
Ben Rose
  • 210 posts
Posted 20 June 2019 - 03:41 PM
So maybe a stupid question but the plastic headlight buckets seem to be riveted on, is that right?
#36 Steve220
Steve220
  • 5,123 posts
  • Local Club: BMC
Posted 20 June 2019 - 06:40 PM
Yep!
#37 Ben Rose
Ben Rose
  • 210 posts
Posted 20 June 2019 - 07:23 PM
Cheers Steve!
#38 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 07:27 AM
So I got to continue stripping down the front end last night.
To repair or not to repair the bonnet?
48101629586_73489b8cbe_b.jpgIMG_20190620_102441
48101739017_3f6999284f_b.jpgIMG_20190620_102447
Virtually nothing left of this front lip...
48101738972_c43b3b6caf_b.jpgIMG_20190620_102451
Pretty serious corrosion on one of the strengthening bars...
48101681903_75d6ecd293_b.jpgIMG_20190620_102456
Small amount of corrosion near the hinge...
48101738862_6885288a6f_b.jpgIMG_20190620_102511
48101629061_f87ce8bf5b_b.jpgIMG_20190620_102514
Grill seems in good order and shows no sign of rust.  I hate the self tapping screws holding it in so I think rivnuts may be the way forward.
48101681483_7c0df5f060_b.jpgIMG_20190620_104556
Front end so far...
48101738332_d185acd948_b.jpgIMG_20190620_104606
#39 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 07:46 AM
I've split my post as there are quite a few images.
Clearly she's going to need a complete front end.  What do you do about VIN numbers etc?
48101628546_0d77c2b27c_b.jpgIMG_20190620_104616
Should this be put on the new panel?
48101628336_26a893d546_b.jpgIMG_20190620_104622
And this?
48101822522_3d4c52140b_b.jpgVIN Number
Noticed a crack in the alternator so this will need to be replaced too...
48101737882_92238c40cd_b.jpgIMG_20190620_104628
Corrosion around the headlight is bad...
48101680838_e346af21c1_b.jpgIMG_20190620_105738
48101680468_524e5dc5c5_b.jpgIMG_20190620_105751
48101736502_41fe8a4048_b.jpgIMG_20190620_111316
Front bumper seems in good order so spent ages trying to get the sheered off bolts off without twisting the bumper.  First bit of angle grinding I had to do and got it off OK.  Seems a stupid way to attach the bumper to the car as they are always going to brake when the bolts get a bit rusty.
48101680243_fb2dab2eed_b.jpgIMG_20190620_105800
48101736922_ffddf937be_b.jpgIMG_20190620_111300
48101736232_5418938307_b.jpgIMG_20190620_194212
48101626651_a3ea15138d_b.jpgIMG_20190620_194219
Pile of parts is growing...
48101736152_beef2ca627_b.jpgIMG_20190620_194238
Edited by Ben Rose, 21 June 2019 - 07:46 AM.
#40 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 21 June 2019 - 07:47 AM
I'm not best placed to advise on whether that bonnet can be saved, but whatever you do, keep hold of the spring latch and also the spring loaded arm. These don't come included with heritage bonnets and I had to rescue mine from the scrap bin at the body shop yesterday so that they can be transferred over.
#41 Steve220
Steve220
  • 5,123 posts
  • Local Club: BMC
Posted 21 June 2019 - 07:57 AM
Depending on your budget, but a new bonnet. Remove the VIN plate and the body number stamping and transfer them to the new panels.
#42 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 07:58 AM
I've drilled out the rivets holding the headlight buckets into the wing...
48101678828_df421a00f6_b.jpgIMG_20190620_194847r
Clips holding the cables in had come out of inner wing...
48101626341_77be73290d_b.jpgIMG_20190620_194851
All looking very crusty!!
48101626286_93c360c37a_b.jpgIMG_20190620_194855
48101678653_fc5144a1d7_b.jpgIMG_20190620_194859
Plant matter growing out of the headlight seals (what you get for being off the road for 5 years I guess)
48101735737_eec112219a_b.jpgIMG_20190620_195251
48101678508_65b0aa29b8_b.jpgIMG_20190620_195304
#43 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 08:06 AM
Bit of help please as I'm sure there's a way of easily doing this. How do I get the wire out of the bucket without cutting the wires?
The bulb end seems to be soldered on and I don't know how to get the multi plug end off. I guess I could heat the solder up to release the wires from the bulb end?
48101735562_20fd5a82fd_b.jpgIMG_20190620_195847
Dropped the coolant which I should have done 5 years ago...
48101625431_5b524ede26_b.jpgIMG_20190620_201352
48101625041_ce30e01a7f_b.jpgIMG_20190620_201419
I was worried about the colour until I found the original coolant I put in the car which was red..
48101677728_de6e577827_c.jpgIMG_20190620_201401
#44 Ben Rose
Ben Rose
  • 210 posts
Posted 21 June 2019 - 08:20 AM
Great - thanks. I will make sure I do both.
#45 unburntfuelinthemorning
  • 2,003 posts
Posted 21 June 2019 - 08:34 AM
At the bulb end the spades normally have small tabs which catch on the plastic part.  You may be able to unhook them using a really small screwdriver or something.
