Piston Question
engine
6 replies to this topic
#1 ABM_Restoration
ABM_Restoration
  • 14 posts
  • Local Club: Norsk Mini Cooper Club
Posted 02 May 2020 - 07:20 PM
Hello
I am rebuilding an 1275 engine for my Mini and need new piston rings.
Can anyone help me figure out what sort of piston this is ?
Attached File  B6CE57AC-183F-41C5-BCD2-E6AB0CD91169.jpeg   138.32K   0 downloads
Attached File  A5F963DF-8FF7-441F-B848-2E747DDCF3CD.jpeg   39.79K   1 downloads
Attached File  4A51FAAC-0893-4EBD-B571-BA6DA5EB340B.jpeg   56.75K   4 downloads
Andreas
#2 Spider
  • 13,930 posts
Posted 02 May 2020 - 07:57 PM
The measurement you've taken - is that of the bore or the piston ?
If it's the piston, where on the piston did you take this measurement ?
#3 ABM_Restoration
ABM_Restoration
  • 14 posts
Posted 02 May 2020 - 08:44 PM
It’s on the outer edge of the piston
#4 nicklouse
  • 17,945 posts
Posted 02 May 2020 - 08:53 PM
reminds me of the standard ones we used to bin.
#5 Spider
  • 13,930 posts
Posted 02 May 2020 - 09:06 PM
It's a standard Low Compression 1275 Piston.
The current AE Rings don't fit these, but just about any other brand will.
#6 ABM_Restoration
ABM_Restoration
  • 14 posts
Posted 03 May 2020 - 10:58 PM
Thanks, so the best thing to do is get new pistons then ?
At the moment the engine is stock with a better camshaft, but for the next season the head will be ported.
#7 nicklouse
  • 17,945 posts
Posted 03 May 2020 - 11:21 PM
 I would not bother using them if you are planing on something not standard.
have a good look inside at the opening for the oil from the oil scraper set. Or just pop the rings off. IIRC there are two massive slots cut. One each side. Unlike better standard pistons that have a ring of smaller holes.
