Posted 16 May 2020 - 10:55 AM
TIA
Posted 16 May 2020 - 10:57 AM
Put something through the hole and try to move the holder.
Posted 16 May 2020 - 10:59 AM
Try putting the piston in a saucepan (other utensils might be available) with very hot water. Different materials expand at different rates. Sometimes the optimum time to try the removal is as it all cools down.
Edited by whistler, 16 May 2020 - 10:59 AM.
Posted 18 May 2020 - 10:09 AM
Nicklouse: Tried that but there is only a slot .. the base of the needle holder is below the hole so nothing to push down on ..
Whistler: Will try that this week when SHMBO isn't around so can't see my boiling up engine parts in her new saucepans!
Posted 20 May 2020 - 02:05 PM
Got it out .. but ended up with brute force ..
The needle holder must have been splayed but over-tightening .. as it just refused until I wrapped the needle in tons of masking tape and gentle levered it out with pliers .. heating didn't work, and a screw driver just made it rotate slightly ...
It wasn't even the needle type I need so that was a waste of time really .. had I know that ...
But many thanks for the suggestions ..
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , Yesterday, 07:03 PM ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
