Mc Gmc159 Vs Gmc160
brakes
Best Answer normini , 05 August 2020 - 09:40 AM
I have got an other master cylinder. I am not sure if this could be a GMC159. The upper piston and the spring are different from my GMC160. The right piston and spring are fro my GMC160, for the diagonal split brake system. Could the left piston be GMC159 for the front/rear split system. It will be nice if someone can conclude on this subject.
The cylinders, lower pistons and piston linkages are equal.
I have now got a GMC159 master cylinder from Germany. The GMC159 upper piston is equal to the piston on the left in the picture.
Go to the full post
17 replies to this topic
#1 normini
normini
    Just On Tickover
  • 8 posts
  • Local Club: NMCC
Posted 19 May 2020 - 11:17 AM
I shall change the brake system from diagonal split to front/rear split. The diagonal split system use MC GMC160, the front rear split system use GMC159. Both use the same repair set. What is the difference between the two master cylinders? I have GMC160. Do I need GMC159, or are thy interchangeable?
#2 Spider
  • 15,819 posts
Posted 19 May 2020 - 06:46 PM
I think you'll find the only difference between these is one has Imperial Threads for the Tube Nuts and the other is Metric.
#3 normini
normini
    Just On Tickover
  • 8 posts
  • Local Club: NMCC
Posted 21 May 2020 - 03:04 PM
In the link below, I found this:
". . . The same main casting was used on the GMC159 and GMC160 diagonal split master cylinder, so, externally, one can't tell the two versions apart. There are slight internal differences, such as one piston is slightly different, so these are not interchangeable with the GMC159, . . . ."
https://www.7ent.com...r-cylinder.html
On a German site I found an other explanation and a drawing.
https://www.mini-for...934-Inno-GMC159
It says that the part no. 15 should be removed from the lower position/front system to convert GMC160 to GMC159.
I am confused and would like to know what is correct.
In Norway I can get hold of used GMC160s, but GMC159 is hard to find I recon.
#4 Ethel
  • 26,758 posts
Posted 21 May 2020 - 06:07 PM
Could be a residual pressure valve to reduce pedal travel by keeping the brakes from backing off fully. That wouldn't be very desirable on only one front brake in a diagonal split system!
#5 Spider
  • 15,819 posts
Posted 21 May 2020 - 07:44 PM
The scant bit of info I have on these Cylinders suggests that there's a residual pressure valve, referred to as a 'trap' under both outlets on the front / rear split cylinder.
<Edit:- in the last year of production, the threads in these did change from Imperial to Metric, but, it appears that it was just the adaptors near item 15, that were changed. >
Edited by Moke Spider, 21 May 2020 - 08:57 PM.
#6 Ethel
  • 26,758 posts
Posted 21 May 2020 - 11:05 PM
Interesting, wonder if that was just an Ozzie thing. I think they were careful with hydraulics here not to make anything metric that could accidentally be used to replace a superseded imperial component.
#7 Spider
  • 15,819 posts
Posted 22 May 2020 - 06:06 AM
No, it was a UK-ish thing. We never had these Cylinders here, though, a very small few found their way on to Race Car to meet the regs of the day. There was a reference to the change in the threads on a fiche.
I agree with what you are saying re thread confusion, however the GMC 167 was fitted for front / rear split and GMC168 for diagonal spit however, the only difference between these cylinder is that the 167 has metric threads and the 168 imperial.
#8 croc7
croc7
  • 894 posts
Posted 22 May 2020 - 06:56 AM
#9 croc7
croc7
  • 894 posts
Posted 22 May 2020 - 06:59 AM
I have a GMC159 rebuilt and preserved with Castrol Red Rubber Grease if you are interested.
#10 normini
normini
    Just On Tickover
  • 8 posts
  • Local Club: NMCC
Posted 22 May 2020 - 11:58 AM
PM sendt.
#11 normini
normini
    Just On Tickover
  • 8 posts
  • Local Club: NMCC
Posted 25 May 2020 - 02:05 PM
My master cylinder, GMC160:
Attached File  Målsatt GMC160.JPG   31.33K   8 downloads
Attached File  Målsatt UNF.JPG   36.87K   7 downloads
Attached File  Målsatt pushrod.JPG   27.63K   9 downloads
Attached File  Målsatte stempler.JPG   42.21K   8 downloads
#12 normini
normini
    Just On Tickover
  • 8 posts
  • Local Club: NMCC
Posted 08 June 2020 - 01:09 PM
Attached File  Upper pistons.JPG   25.49K   23 downloads
#13 Spider
  • 15,819 posts
Posted 08 June 2020 - 08:10 PM
Just looking at the 2 pistons here, it appears that when fitted, the seals between the 2 types will 'park' at different heights within the cylinder - Am I seeing that right?
If that's the case, then I'm sure the ports between the cylinder and the Reservoir would also be at different heights too.
#14 normini
normini
    Just On Tickover
  • 8 posts
  • Local Club: NMCC
Posted 09 June 2020 - 04:09 PM
The cylinder outlets and reservoir ports are equal.
Could it be that the rear slave cylinders will require less brake fluid than the front slave cylinders?
In a diagonal split system, fluid requirements will be equal for both systems.
#15 croc7
croc7
  • 894 posts
Posted 11 June 2020 - 05:31 AM
Also tagged with one or more of these keywords: brakes
