That Old Black Magic '2'
68 replies to this topic
#16 Gazza211
Gazza211
  • 77 posts
Posted 15 December 2008 - 10:01 PM
Hi
No more welding done for a couple of weeks due to the cold weather, but i have stripped the front calipers, the pistons were well past their best, i have obtained some new seals, stainless pistons, pads and fitting kit, i will fit them back together later this week, i have also got the front and rear harnesses back which have been re-wrapped, new connectors where necessary and a new fuse box has been fitted, i will take some photo's later this week.
Gaz
#17 giz
giz
  • 747 posts
  • Local Club: ubmc
Posted 15 December 2008 - 10:07 PM
if i manage to make it over tomorrow i'll have to have a sneaky peak at this!
#18 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 16 December 2008 - 11:26 PM
Ditto :thumbsup: Looking good buddy,...Ever need a hand, I'm just on the top of rock hill :thumbsup:
#19 Gazza211
Gazza211
  • 77 posts
Posted 19 December 2008 - 11:38 PM
Hi
Made some more progess this afternoon, got the shell out of the garage (first time in 4 years) and turned it around to start on the other side.
The NS quarter panel was just as much a bodge as the OS, too many flanges, poor welding and loads of corrosion
The quarter panel is now removed along with a section of sill that was corroded, then a dilemma, the edge of the arch was completely rotten but i had bought a complete arch panel, as the shock absorber mount and back face of the arch were in excellent condition i decided to cut my new heritage arch to just repair the corrosion :dontgetit:
Arch cut out and quarter panel removed
Trial fit of arch repair
Just need to clean upall the flanges and weld the arch back together and spot the quarter panel on.
Will post some more piccies when the welding is done.
Gary
Edited by Gazza211, 14 October 2009 - 06:14 AM.
#20 CMcB
CMcB
  • 999 posts
Posted 19 December 2008 - 11:44 PM
oooh thats interesting cause ive got to patch my rear arch with the quarter panel on, it'll be a b***h i reckon, but you're obviously waaay more experienced than me.
keep up the good work dude.
#21 Gazza211
Gazza211
  • 77 posts
Posted 19 December 2008 - 11:48 PM
Hi Craig,
Just use a 2" disc cutter, drill out any spot welds and measure, measure and measure again!
Gaz
#22 CMcB
CMcB
  • 999 posts
Posted 20 December 2008 - 12:42 AM
ive just got a brand new dremel with metal cutting discs so hopefully that'll do it.
#23 buddylove
buddylove
  • 1,640 posts
  • Local Club: SAMOA
Posted 20 December 2008 - 01:48 AM
Good project, great work so far :dontgetit:
#24 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 20 December 2008 - 08:56 AM
saw it outside yesterday, looking good! couldn't stop to say high, macdonalds was calling ;)
#25 Gazza211
Gazza211
  • 77 posts
Posted 05 January 2009 - 02:12 PM
Hi Happy New Year to one and all.
Well had two weeks off over Christmas and never picked up the welding torch ;D but i did manage to get some work done on the engine, the diff bearings and the baulk ring on second were shot so i removed the gearbox and replaced it with a nearly new transmission that i had waiting in the wings.
The power unit i am fitting was originally from an MG metro so has the big valve 12G940 head, as the engine has done a few miles i decided to remove the head, have it skimmed and regrind all the valves, i have also drilled out the blanking for the heater control valve so that i can fit one from a Mini.
I changed the timing chain to a duplex type, fitted a Mini timing chain cover and also changed the clutch actuating system to the Hydraulic Mini type.
I also removed the Modine cooler and am going to fit a standard oil filter mounting when i can get hold of a screw in adapter and metal feed pipe.
The block received a good clean with some brake cleaner and a couple of coats of Red engine laquer (not concours but i intend to use it regulary)
The plan is to use this powerunit to get the car on the road then upgrade to a 1380, so if anyone has a short 1275 A+ engine (that needs a rebuild) they want to get rid of (cheap) in the Bromsgrove area please let me know.
I will endeavour to get back in the garage later on a take a couple of shots of the powerunit now its all shiny and post them up asap.
#26 Gazza211
Gazza211
  • 77 posts
Posted 05 January 2009 - 02:55 PM
Hi again
While i am online i thought i might just post a picture of my first car (Black Magic 1) that has inspired this build. ;D
Edited by Gazza211, 13 October 2009 - 08:43 AM.
#27 flat-eric
flat-eric
  • 435 posts
  • Local Club: anyone that will have me?
Posted 05 January 2009 - 04:36 PM
keep with it Gazza!
its looking very solid now!
rob
#28 Gazza211
Gazza211
  • 77 posts
Posted 05 January 2009 - 08:39 PM
Hi
He is a photo of my nearly completed 1275 powerunit.
Cheers Gaz
Edited by Gazza211, 14 October 2009 - 06:16 AM.
#29 beaubrad
beaubrad
  • 736 posts
Posted 06 January 2009 - 05:37 PM
iv got one of these ,really good for cutting small patches, your first mini looks well nice will this 1 look the same??? brad
#30 Gazza211
Gazza211
  • 77 posts
Posted 07 January 2009 - 08:08 AM
Well thank you sir.
My original Mini was totally standard but this one will have a more modern twist, 12x6 deep dish super lights, possibly group 2 or 5 arches and fully adjustable suspension, hopefully the paint will be even more shiny than the first one as i have had a few years of spraying practice since then! ;D
