The Real Mini Project
979 replies to this topic
#691 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 01 June 2009 - 10:40 AM
Ahh kool. How much they taking out of them?
Hopefully a 6cc dish.
#692 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 01 June 2009 - 10:42 AM
Sweet. You taking anything out of the head aswell?
#693 JordanRaisbeck
JordanRaisbeck
  • 408 posts
  • Local Club: NEMC
Posted 01 June 2009 - 10:48 AM
Heyy mate, im also a park lane owner *thumbs up* and its a shame to see one crashed into. But its great that your repairing her :dontgetit: Good luck on completing :crazy:
Jordan.
EDIT: Spelling
Edited by JordanRaisbeck, 01 June 2009 - 10:49 AM.
#694 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 01 June 2009 - 11:39 AM
I'll have to mess around with it an see what works, all that has been given to wire up the alarm is a simple diagram thats no bigger than my mobile, so its hard to understand some of it, and I think its been translated to english, so its not the best :crazy: . Might get a chance to look at it tomorrow.
The hazards have a constant feed that pulses through the flasher, give it a pulsing feed and it's going to go all funny. You just need to connect one brown wire to one side of the indicators and the other brown wire to the other side. There are a few funny wires on an alarm, but there all there for a reason, the brake light circuit is another way of triggering the alarm/ immobilisor I think, just incase they can bypass the door switches, put your foot on the brake and it will go off. I think.
Anyway car is looking good, and im very jealous of the s/c setup you have there.
Edited by mini_mad69, 01 June 2009 - 11:39 AM.
#695 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 01 June 2009 - 03:11 PM
Yer have to, not sure how much yet though, I think it is going to be a lot though :unsure: .
Heyy mate, im also a park lane owner *thumbs up* and its a shame to see one crashed into. But its great that your repairing her ;) Good luck on completing :)
Jordan.
EDIT: Spelling
Nice to see another owner, and thanks for the positive comment =] .
Ah I think I know what you mean :huh: , so I'll try some things. I'm finishing college early today, so might get a bit of time on the mini :thumbsup: . Cheers and I like the S/C set up too :wub: .
Cheers guys :D .
#696 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 01 June 2009 - 07:17 PM
Just come in from being on the mini, done a little more wiring of the alarm, the only things I'm still confused with are :thumbsup: :
1. There is a wire that goes to the "Negative trigger switch of side door", where does that go?
2. A wire that goes to the "Engine cut-off circuit", where does that go?
3. And the wires that go to the indicators, but where do they go? Because I don't want to connect each one to each of the indicators individually :D .
There is also a relay that came with the kit, but not sure what that is for? I will try and get a picture up of the wiring diagram soon.
Nearly there with the wiring now, once the alarm is in, just need to wire the speakers in etc, then solder each of the joints in the wire, then it will be all good =] .
#697 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 02 June 2009 - 06:49 PM
Went out on the mini tonight, but it has really p*ssed me off, trying to tidy up all the wires, but know matter how much I cut or add, they don't seem to be getting any tidier :turtle: , also now thinking it might not see the roads this year :) .
#698 mini_mad69
mini_mad69
  • 5,417 posts
Posted 03 June 2009 - 12:48 AM
Im not security expert, but I'll try help.
The small door switches near the A panel, same circuit as the interior light. Attacth it onto this wire.
Don't know that one sorry, may be linked into the immobilisor if the alarm has one.
3. And the wires that go to the indicators, but where do they go? Because I don't want to connect each one to each of the indicators individually :P .
You don't have to wire them individualy, you said before that there were 2 brown wires, just connect 1 brown wire to the posotive side to one of the indicators on the right and one on the left of the car. Connect it to one indicator and it will power all of them on that side, as they're all linked together on each side.
This will probably be for the immobilisor if the alarm came with one, I know mine did. Im not sure about your's but with mine once the alarm is deactivated it latches the relay allowing power to flow to the ignition. This may also be to do with the "engine cut off circuit" mentioned earlier, I didn't bother connecting mine up as it was just something to go wrong, but it's up to you. If you scan in your wiring diagram it may help people help you further. Good luck.
Edited by mini_mad69, 03 June 2009 - 12:49 AM.
#699 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 06 June 2009 - 04:42 PM
Thanks for that mini_mad69, I get what you mean now :(.
Update coming people :P .
#700 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 06 June 2009 - 04:56 PM
Right, well its about time for an update :( . After my mini p*ssed me off the other day, I gave it a rest on Wednesday, and then Thursday we had to go and pick up some chickens, so no work there, and then yesterday, I finally got started on the electrics :( .
After a lot of cutting, pulling, soldering and swearing, I got the engine bay from this:
To this:
To me that looks pretty good going, and once I got started, I really got stuck in. But the engine bay wasn't the main problem, it was the interior electrics :P , so from this:
To this:
It doesn't really look it, but it is a lot better :( . And it shows with how much wire I have cut and removed:
There is a fair amount there :o . Anyway, I should hopefully have that all done buy tomorrow, and when the electrics are done, I can get started on installing my new:
Oh yes :w00t:, two :o JBL subs:
Diameter = 10"
Sensitivity = 91db (2.83V @ 1w/m)
Power Handling = 500W (125RMS)
Frequency Response = 38Hz - 800Hz
Nominal Impedence = 4 Ohms
Mounting Depth = 116mm
Cutout Diameter = 229mm
They should be nice in the mini ;) , thats all for today people.
Edited by 1987_ParkLane, 06 June 2009 - 04:58 PM.
#701 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 07 June 2009 - 04:47 PM
So, cracked on with a litle more work today. I went to start doing the electrics again, but I forgot that I had ran out of solder :P , and Halfords didn't have any, so I used up the last few little bits I had and that was it for the wiring today :wub: . I'll get so more solder from Parkers or somewhere in the week so I can carry on with them :genius: .
So the I started going about making some new rear quarter cards. And after a lot of cutting and fiddling, they came out pretty well:
I am going to cover them in carbon fibre vinyl. Then I thought I would see if the subs would fit where I wanted them:
Turns out no :lol: lol, so I am going to have one in the boot, if I can't find a place for both of them. Any ideas :wub: ?
Note to self, when purchasing items, make sure they fit before buying :lol: .
Thats all for today :wub: .
Edited by 1987_ParkLane, 07 June 2009 - 04:48 PM.
#702 camp freddy
camp freddy
  • 3,696 posts
Posted 07 June 2009 - 09:49 PM
Right, well its about time for an update :D . After my mini p*ssed me off the other day, I gave it a rest on Wednesday, and then Thursday we had to go and pick up some chickens, so no work there, and then yesterday, I finally got started on the electrics :) .
To this:
To this:
It doesn't really look it, but it is a lot better :X . And it shows with how much wire I have cut and removed:
Oh yes :w00t: , two :o JBL subs:
Diameter = 10"
They should be nice in the mini :crazy: , thats all for today people.
they look the same as in my boom box
think they cost me £28 incl delivery
#703 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 07 June 2009 - 10:00 PM
Correct, they are the same ones :P
I've an idea where to put the other sub, in my car :D lol
Wiring looking good. Have you got any vinyl yet?
would you be able to fit the 2 subs where they are in the pictures but angled back so they point up slightly in a custom made speaker board?
#704 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 08 June 2009 - 10:17 AM
Yes they are, but they were £30 incl delivery :o .
Correct, they are the same ones :)
I've an idea where to put the other sub, in my car :o lol
No got no vinyl yet :X , hopefully soon, after I have made the front door cards :P . I thought about doing that, I will see how much they will have to be tilted up to fit :crazy: .
But also I think funds might be lowered a bit for a while as I'm going America next year and need to save about £100 a month to go :w00t: , but it should be ok, I hope :D .
#705 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 08 June 2009 - 07:25 PM
A nice package turned up today:
A nice set of shiny new pistons :angel: , +40 thou and ready to be machined :P . Only one thing, one of them was missing this pipe/tube thing (I don't know the name of it lol :) ):
So I have emailed Simon to see if he can send me one by Thursday as I need it for Friday so I can give them to MED, hope he can :dontgetit: .
