Primed it, filler primed it and the flatted it, and now it ready for a top coat
Posted 19 July 2009 - 04:13 PM
Posted 20 July 2009 - 07:16 PM
Posted 20 July 2009 - 07:24 PM
Edited by 1275 SPRITE, 20 July 2009 - 07:25 PM.
Posted 20 July 2009 - 08:11 PM
Boots looking nice
How many coats have you given / giving it?
Boot latch looks to be coming along now.
Not great about the wait with the engine bits, but will definately be worth the wait
Price seems ok too. Thought he would have knocked a bit more off for cash though.
Posted 20 July 2009 - 08:22 PM
Posted 20 July 2009 - 08:25 PM
Was £330 cash or was that full price? If that was retail, I'd expect around £40 - £50 off that.
Once the engine bits are ready, it shouldn't take long to build, Mine was a lot easier than expected, although not quite done yet!
Have you sorted a Cam Kit out yet??
Posted 20 July 2009 - 08:35 PM
First off today I had to modify the latch that is going to go onto the inside of the boot:
It will make it easier to house, which is what I stated to make next:
I'll weld these together tomorrow at work, then a bit of bending, and it will be the perfect housing for the latch.
Also, does anyone know of any really strong adhesive that will never come off, and can handle a lot of pushing and pulling?
Next up was time for fabricating a bracket for the inside lactch, for the boot latch to lactch onto lol:
Its very simple, but it will do the job. When I have found the perfect angle for it, I might weld a support piece on the underside of the bracket to strengthen it
At last, but not least, throughout the afternoon I had been spraying my boot:
Its not looking to bad at the minute.
Also today I rang MED to see how my block and crank were getting on, but not good news, still not done yet
. And it wont be done until the end of next week
, but I asked him how much it was going to be, and for:
- +40thou bore
- Cam bearings
- Reface
- Pockets
- And reground and heat treated crank
He said we can do a deal around £300 cash, which I think is not a bad deal, what do you all think
Posted 20 July 2009 - 08:36 PM
Posted 20 July 2009 - 08:42 PM
what are you sticking and what too ??????
Yes it would be a good idea to get the engine out of the car. It will save rushing when the engine is ready to be built.
Are you going to rebuild the box yourself?
I think there is quite a few other bits you will need for the engine build i.e big end and main bearings, thrust washers, core plugs, oil gallery plugs, new con rod bolts, cam, duplex timing pulleys, followers, oil pump, possible head?, and all the gaskets.
I think there will be around £250 worth there without the head.
Posted 20 July 2009 - 08:50 PM
Posted 20 July 2009 - 08:51 PM
Course it will get done, I'm just trying to make sure you dont forget anything
MED do those cam kits cheap, for £175 (retail), which includes a Piper cam with your choice of profile, a Piper vernier setup with new chains, a new oil pump and new followers. Thats pretty much all you need bar gaskets & bearings, which can be bought cheaper from mini spares.
dont worry, we'll sort it. At least you are only paying for parts and saving a small fortune for building it ourselves
Posted 20 July 2009 - 08:58 PM
Edited by camp freddy, 20 July 2009 - 09:16 PM.
Posted 20 July 2009 - 08:59 PM
Yer my main concern at the moment is getting the engine out, and getting the gearbox sorted.
Posted 20 July 2009 - 09:07 PM
I can bring home some adhesive we bond ally panels on with from work , that will
do the job... we use it on modile libraries and buses...
when are you removing the engine??
Posted 20 July 2009 - 09:19 PM
