Mini Sidewalk Project. *finished!*
#31
Posted 04 December 2008 - 02:17 AM
#32
Posted 05 December 2008 - 11:32 PM
Problem is, there's wires going from the coil to the ECU, and then a few more, so i'd need to extend those wires and route them back to the engine bay, which I really can't be bothered to do! Just incase I get it wrong, and mess it up.
The reason for having the ECU inside, is basically so it won't get wet. Seeing as it was nicely tucked up and bolted the the inner wing, it never saw water! But now the inner wing has gone, so I need to find it a new home.
Was thinking about making a mount to fix to one of the brace bars, and have the ECU on there, then maybe just cover it up with a Tesco bag or something? Just to keep it water-proof...
What do you guys think?
#33
Posted 06 December 2008 - 01:13 AM
#34
Posted 11 December 2008 - 08:21 PM
FINALLY recieved my cheque in the post! So now I've cashed that in, just need to wait for that to clear, then I can start spending all my money!
Seeing as I couldn't do much else, I started working on my custom grill.
Ground all the rivets off the old one, pulled all the slats and surround off, then picked all the paint off. I was left with a nice and rusty grill backing, so I got the grinder/flap disk out and tidied it all up a bit.
Found half a can of red spray paint in the car, so I thought I'd brighten it up a bit!
Finished shot of the front:
I ran out of red paint half way through spraying the back, so I had a rummage in the garage, and found half a tin of white spray paint! So I finished it off with that. You'll never see the back, just needed to cover it all up so it (hopefully!) doesn't rust again.
Bit of a red/pinky/white mess!
Just need to either fit the top surround to the grill somehow, or get the bonnet with the lip, and bolt it onto that. Any ideas what'd be best?
Going to order some black mesh for it once I have money, and then have my checkered wing badge in the middle.
#35
Posted 12 December 2008 - 03:47 PM
ABS Fibreglass flipfront, S bonnet, brace bars, hinges.
Halogen headlamp kit.
Headlamp bowl kit.
Headlamp rims.
Mk1 indicators.
Fuel sender unit and seal.
Engine stabilizer.
Locking bonnet pins. - Back of bonnet.
Normal bonnet pins. - Front of bonnet.
Rubber bonnet hooks. - A panel/flipfront join.
K&N air filter.
Stick-on numberplate.
Battery earth cable.
Black mesh. - For my custom grill.
Rubber trim. - for the rear bumper seam, as i'm removing the rear bumper, and can't be bothered to de-seam it!
AdjustaRide kit.
Gunna be sat at home all day Monday/Tuesday/Wednesday waiting for parcels!
Can't wait now. Gunna be low and loud, with a working fuel guage, no dodgey earth connection, and looking very rally!
Thinking about getting my Recaro seats covered in leather to finish it all off, but we'll see how my bank balance is looking after my christmas shopping is done...
#36
Posted 13 December 2008 - 03:51 PM
Also cant wait too see this done
#37
Posted 14 December 2008 - 12:01 AM
#38
Posted 14 December 2008 - 11:16 AM
Do you know what the rules are about having side repeaters? I really don't want them! But I drive a 1990..
#39
Posted 14 December 2008 - 04:42 PM
Got it from MiniSport. I get 3 Mini models too!who did you get the adjustaride kit from? Still trying to decide which one I want.
Don't know the exact rules on side repeaters, all I know is that I have to have them.
#40
Posted 14 December 2008 - 04:49 PM
You'll have to have them I'm affraid chap, mine is an '88 and I have to have them too. I'm thinking about putting mine in the a-panel instead of the front, but I'm not 100% sure yet.Quality
I don't get my front flip until Christmas but I've started buying parts already
I got £40 for babysitting last night so parts will be coming swiftly!
#41
Posted 14 December 2008 - 05:13 PM
I'm doing that with mine now. Figured it'd be easier to flip the front forward without the side repeater cables getting in the way...I'm thinking about putting mine in the a-panel instead of the front, but I'm not 100% sure yet.
#42
Posted 14 December 2008 - 05:42 PM
I'm also going for low, wide & fast.. once this flip front is done I'll be converting to 10" wheels I think. Are all your panels in good condition then? Things like the inner wings & the scuttle support panels?
#43
Posted 15 December 2008 - 09:04 AM
Other than that, it's all good! Suprisingly I found no rust at all under the wings. Scuttle panel, etc is fine!
UPDATE:
Adjusta Ride Kit: Delivered!
Will have a go at fitting it a bit later.
EDIT: After a quick look at the Mini, it looks like it might already have Hi-Los on it! Which I didn't know! So that's annoying! Might just lower it on those to save hassle... Plus I don't have a spring compressor.
Edited by Dan6061, 15 December 2008 - 09:57 AM.
#44
Posted 15 December 2008 - 04:02 PM
My bank thought that some dodgey transactions were going on with my card, so they stopped a few of them. Had to ring them and explain what was going on! Should all be sorted now!
Suppose they're not used to my account suddenly getting so active!
#45
Posted 15 December 2008 - 04:32 PM
