Ted - 1963 Mk1 Resto
197 replies to this topic
#61 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 08 May 2009 - 05:35 PM
MK4 Side panel modified and fitted
Tacked up
Spot welded
Front seam done, just needs to be flattened back
Inside
Edited by ratty, 08 May 2009 - 05:36 PM.
#62 mymini007
mymini007
  • 2,046 posts
Posted 08 May 2009 - 05:52 PM
I picked up a couple more panels today, so tomorrow after work I can start grinding again
I also have these to go on the back end :P
Congrats on winning the brakes John, I saw Connies pic in the mag, nice 1 :D
#63 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 16 May 2009 - 03:32 PM
Last part of the boot floor made and fitted
MK1 Valance closing plates made
Valance trial fitted
Petrol tank support fitted inside boot
#64 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 16 May 2009 - 08:12 PM
Your doing excellent work there mate, wish i was as skilled as you :D :D
Edited by cookie4343, 16 May 2009 - 08:13 PM.
#65 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 18 May 2009 - 01:20 PM
Engine plans may have to change due to stumbling upon a 998 Cooper engine (yet to be confirmed but hopeful)
#66 tedmcedd
tedmcedd
  • 2,751 posts
Posted 18 May 2009 - 02:58 PM
sounds great! i have some cooper discs and calipers if you want?
#67 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 20 May 2009 - 05:18 PM
Not much to show for the past few days as its all just grinding back welds etc, but I did make another large hole in the car
Edited by ratty, 20 May 2009 - 05:19 PM.
#68 davos1983
davos1983
  • 45 posts
Posted 22 May 2009 - 07:50 PM
Sill strengthener and arch closing plate fitted
Hi - do you have a part number for these sill strengthers and closing plates? I was unable to spot them on Somerford when putting mine together?
If you can point me in the direction thatd be great!
Awesome progress by the way - its taken me 2 years to do what you've done in a couple of weeks!
#69 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 22 May 2009 - 08:59 PM
Parts 11 & 40
http://www.somerford...x...1&chapter=5
#70 Goopster
Goopster
  • 128 posts
Posted 22 May 2009 - 09:09 PM
Stunning work, as always Ratty. I wish I could butt weld as well as you. Whenever I try, I just seem to blow holes and widen gaps LOL. What am I doing wrong? I find it easier to overlap plates or panels very slightly, but as a result, its nowhere near as neat as what you are doing.
This car is going to be stunning. And the speed at which you work is something else!
All the best, Goopster
Edited by Goopster, 22 May 2009 - 09:13 PM.
#71 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 22 May 2009 - 09:29 PM
Ensure the gap in the panels is no more than 1mm, the metal edges need to be clean but don't grind them too thin when doing this. Find a setting on your welder that allows for quick pulse welding by practicing on scrap metal first. I also find a heat sink held at the back of the weld helps if the gap between the panels is too large
#72 Goopster
Goopster
  • 128 posts
Posted 22 May 2009 - 09:35 PM
Thanks Ratty, much appreciated. I'll have a practice on some scrap then give it a try on the next area I tackle (probably my door posts)
All the best, Mark
#73 lchris21
lchris21
  • 106 posts
Posted 23 May 2009 - 06:56 AM
Some top fabrication going on there. Keep up the good work !
#74 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 24 May 2009 - 07:06 PM
A bit of a lazy weekend but some work has been done
N/S/R wing fitted
Cut a hole accross the back
Be a bit rude not to fill it though
Just got to fit valance to complete the back end
#75 tedmcedd
tedmcedd
  • 2,751 posts
Posted 24 May 2009 - 10:16 PM
amazing as always!
