Fern...
#151
Posted 19 December 2011 - 08:00 PM
#152
Posted 19 December 2011 - 09:08 PM
#153
Posted 22 December 2011 - 07:06 AM
I decided to leave the boot for now & take a look under the drivers sill to see what I'm dealing with. My first reaction was 'holy c'#p'! followed by why would they do that?! This, kids, is why you dont play with a welder if you dont know what you're doing!
Looks like no prep has gone into the outer sill what so ever as it still has the sticker on it. All they did was slap the sill over the old rusty one & then to top that off they then plated straight over the rust holes on the inner sill too. Rust sandwich anyone?
Once I had the outer sill off I took as much of the old sill off as I could, it was difficult as there were 3 patches on that as well.
inside one of the patches on the inner sill
Front part (or whats left of it) of the drivers sill(s)
Chopped most of it straight out, still need to remove some more metal but I need to tidy up around it first to see how far back to go. Notice the jacking point rust & the hole which literally fell apart as I touched it straight inside the cross beam.
Another untidy 'repair' made by the cough 'professionals' cough
Edited by Brams96, 22 December 2011 - 07:07 AM.
#154
Posted 22 December 2011 - 07:18 AM
#155
Posted 26 December 2011 - 01:09 AM
Stay tuned . . .
#156
Posted 29 December 2011 - 10:53 PM
I had to slowly grind down the metal & peel it away once thin enough, but in the end I managed it. I also drilled out all the spot welds on the inner sill to door step & had to grind away & peel off the remaing sills from the door step too, that took ages!
Next I cut out the rot from around the front flitch panel & floor pan & decided I will fabricate a new piece with no drain holes. I am a little concerned about the rust inside the cross member as I didn't count on having to remove it completely, de-rust, paint & reweld the whole thing! Any suggestions about how to tackle this are very welcome.
So anyway, here are a few pics to show what I have done.
Bracing
Nice big hole in the floor
Inside the cross member & floor
As it is at the moment
The other part I'm not sure how to tackle is at the front, it's hard to tell but it's the corner seams where the inner guard meets the floor & the fire wall (near the shock mount) Should I chop out the whole section then rebuild it a layer at a time? Again any suggestions?
I hope to start on some welding early next week so stay tuned (if anyone's reading this
#157
Posted 30 December 2011 - 04:39 PM
If i was you i would have gone for the two half floors with the sill attached, thats the one thing i regret not getting when i repaired mine, plus i worked out afterwards that its only a little bit more when you have to buy the front floors, inner sill repair panels and outer sills! good luck!
Lawrence
#158
Posted 30 December 2011 - 07:13 PM
#159
Posted 05 January 2012 - 06:34 AM
Then I repaired part of the door step in the corner. I started off making a template from cardboard, trimmed it & transfered it to sheet then cut & welded it all in, it's all sanded back flat with one of those multi layer discs for a grinder. It will just need a tiny skim of filler & paint.
I'm still waiting on my new panels to arrive so will carry on with the smaller repairs then do the inner sill before moving to the heal board & boot. One thing I'm not quite sure on is how to remove the hinge panel as there are 3 layers of metal there. Do I just drill the spot welds on the door frame & pull it out from under that? or do I cut back the whole flitch panel & remove the spot welds from the back that way?
Edited by Brams96, 05 January 2012 - 06:38 AM.
#160
Posted 10 January 2012 - 10:40 PM
- rear boot section
- heal board repair ends (both)
- boot hinge rail
- both 4" sills
- LHS complete arch
I forgot to order the repair sections for below the rear lights so might just make them instead.
I also made a start on the repairs to the bottom corner of the foot well/flitch panel. Man trying to simultaneously make 3 panels at 3 different angles only using your eye & measurements from the other side takes ages!! It might be quicker to just buy new flitch panels & go from there. But, still ticking over.
Edited by Brams96, 10 January 2012 - 10:44 PM.
#161
Posted 13 January 2012 - 09:42 PM
#162
Posted 25 January 2012 - 12:04 AM
I also decided to remove the section around the lower hinge hole & made up a patch for it, had to wait till the kurust to dry though so haven't put it on yet. I've also put a patch on the foot board.
This is the other side of the sill/flitch panel, notice the holes in the sill, also the old weld that has small holes in it which was letting in water.
Edited by Brams96, 25 January 2012 - 12:07 AM.
#163
Posted 25 January 2012 - 05:02 PM
#164
Posted 01 February 2012 - 03:30 PM
Just have to get my A into G & brave the freezing temps in the unheated garage!
#165
Posted 04 February 2012 - 08:38 PM
