1983 Mini City E Rebuild
#91
Posted 24 June 2010 - 07:26 PM
#92
Posted 24 June 2010 - 07:39 PM
#93
Posted 24 June 2010 - 07:42 PM
#94
#95
Posted 24 June 2010 - 07:43 PM
#96
Posted 24 June 2010 - 07:48 PM
#97
Posted 24 June 2010 - 07:58 PM
In the first picture I posted they don't and look to be about 2 cm out. Looking at the wing/alignment scuttle theres not 2cm of adjustment.
I think that the front of the car has dropped and at the moment isn't aligned correctly.
#98
Posted 24 June 2010 - 08:00 PM
Look at the stripe on the door and wing, in the 2nd picture(early one), the stripes line up.
Could it be because one of the door hinges is snapped and dropping the door or something?
When you push down on the front of the car , it goes into place better so maybe what you are saying is correct
Any ideas?
#99
Posted 24 June 2010 - 08:02 PM
#100
Posted 24 June 2010 - 08:04 PM
The entire front of the car needs to come up, I don't think that its anywhere near aligned correctly, If you can get the shell to twist just by pushing down on it then you have a BIG problem.
The shell doesnt twist , its because the scuttle isnt connected to the wing in anyway its not sitting right
I'll check it next time I'm at dads and we'll see what its like
Reckon I might have to change the front end then?
#101
Posted 24 June 2010 - 08:08 PM
#102
http://cgi.ebay.co.u...a#ht_536wt_1137
^ this could be good
#103
Posted 24 June 2010 - 08:09 PM
#104
Posted 24 June 2010 - 08:10 PM
#105
Posted 24 June 2010 - 08:54 PM
im with shifty on this one, looks like your shell has dropped one side or twisted somehow, i'd look into making sure its nice and straight before going any further
its good to see you trying to save a mini but some just aint worth saving, if its of sentimental value then go for it but otherwise i'd look into another shell, can be picked up quite cheaply and definitely wont be as much work for you.
good luck
