Looking good, It does take a lot of guts to cut a lot of metal away like that but once you see it all starting to go in it all should be good
My Mini ;) The Second Chapter.
#571
Posted 01 September 2010 - 07:45 PM
#572
Posted 01 September 2010 - 10:35 PM
I do have one question though, how are you going to make sure you put the rear subframe mounting points back in the same place
#573
Posted 02 September 2010 - 06:21 AM
I need to strip down my rear subframe first, then when I'm ready to weld on the heelboard end I'll mount the whole lot up and tack it into place, remove the subframe, weld and dress.
Posted 02 September 2010 - 06:52 AM
#575
Posted 02 September 2010 - 09:26 AM
#576
Posted 02 September 2010 - 12:11 PM
You're using the same method as I am for locating the new heelboard ends then
#577
Posted 04 September 2010 - 09:35 AM
Just popped out into the garage to give my heelboard ends a quick dusting of etch and red oxide to stop them from developing surface rust (cheers for the reminder Adam!)
Ran out of red oxide whilst I was out there and the rest are being stored in my room, along with a number of other mini parts
Can't wait to get some fresh metal in! It will be an amazing transformation!
And just a garage shot
Edited by analogue_radio, 05 September 2010 - 06:02 PM.
#578
Posted 04 September 2010 - 11:04 AM
#579
Posted 04 September 2010 - 10:16 PM
looking good!
Ed
#580
Posted 05 September 2010 - 05:37 PM
I won't bore you with photos so here was the end result of today..
I sorted the gutter rail, rear quarters, arch lips & the holes for the arches themselves.
I need to go round with some filler just to get things completely smooth and satisfactory
And I've got this on its way from Manchester, a Cousin who lives there has collected it, then he'll bring it back to his hometown of Loughborough and we can collect it from there. Which is brilliant because the doors are a huge worry of mine.. I still need to source a driver side though. But to have a passenger side door all 100% tidy and primered is fantastic.
#581
Posted 07 September 2010 - 07:51 PM
Brand spanking new boot light & lock from someone on here, only paid for them 2 weeks and 3 days ago
Lower rear quater, I'll only be using the nearest section closest to the arch.
Rear floors, again I'll only be using the section nearest the boot.
Whilst stripping down my rear subframe (so I can get it mounted up whilst welding in the heelboard brackets) I took this shot, coorr
Dad and I lifted the engine down and plonked it in the front subframe.
Tidy bench! made a bit of a mess with the old curtain
& just a garage shot. I found the meatiest looking cutting disc I could find and lopped the end of the spit as I always had to squeeze to get through!
Oh and I've also switched to the Co2/Argon mix now, I did all the repairs the other day using this.. found it much neater, easier and fluent to work with!
So I've got a brilliant tidy garage now, ready for when I'm next in there.
#582
Posted 07 September 2010 - 08:09 PM
& whoops! looking more and more like a garage in my bedroom! ah well I'll be back to uni soon
#583
Posted 07 September 2010 - 08:14 PM
It will be cheaper in the long run as those small bottles do not last very long.
#584
Posted 07 September 2010 - 08:24 PM
Argosheild light rings a bell so it definitely is what he was telling me about
#585
Posted 07 September 2010 - 08:38 PM
