Project Miglia
159 replies to this topic
#136 rosco454
rosco454
  • 908 posts
Posted 03 January 2011 - 10:51 AM
Thanks for the comments,looking to either buy a new welder or a few bits this week so might have more updates soon.
Cheers Ross.
#137 malcs_miniturbo
malcs_miniturbo
  • 602 posts
Posted 03 January 2011 - 11:16 AM
nice one will keep a eye on this what engine are you going for
#138 rosco454
rosco454
  • 908 posts
Posted 04 January 2011 - 08:50 PM
Engine was going to be a 1293 turbo,I had the engine and a spare ready to be rebuilt but sold them during the summer.Not 100% on what its going to be now,just mulling over the options (and costs! :D )
Only got a little bit done today but progress non the less.I got the a pillar gusset welded in,it was pretty awkward down the inside edge as the seam for the windscreen is right where you want the torch to be and its awkward to get a good view of what your doing.It turned out ok in the end and now both side look the same which is a plus as it had always just annoyed me before.Still need to dress the welds back but will have to wait till next time.
Cheers Ross.
#139 rosco454
rosco454
  • 908 posts
Posted 06 January 2011 - 10:31 AM
Nothing to get exited about but I got the a pillar gusset dressed back and gave it a coat of zinc primer as it was all I had lying around.
Cheers Ross.
#140 Chris C
Chris C
  • 212 posts
Posted 06 January 2011 - 07:51 PM
Looks great, makes me happy to see such a high level of craftsmanship being put into this car. I've been following this thing on TM, didn't realize it was on here.
#141 rosco454
rosco454
  • 908 posts
Posted 06 January 2011 - 08:35 PM
Thank you.Its been on here since I bought it but its been so long between updates that the thread has always been way down the pages :)
Cheers Ross.
#142 rosco454
rosco454
  • 908 posts
Posted 08 January 2011 - 09:19 PM
Got a little bit more done.
When I repaired the door bottoms earlier in the thread I also did some localised repairs on the area where the hinges mount to as that was manky as well and had cracked in places.I was never really happy with it to be honest though as the finished job wasnt very neat and there was rust trapped between the outer skin of the frame and the reinforcing frame the hinges mount to.I was thinking about buying a set of doors with better frames but decided that I way as well see if I can sort these out first.
First job was to get the outer skin off which was a bit tricky without mangling the reinforcing plate behind it.There was quite a bit of rust in there so glad I took it off,here it is cleaned up as best it could be.I gave the area a good going over with rust converter stuff and then a good coating of weld through zinc primer.
Made up a repair section to fit along the back edge of the door with some holes for plug welds to replace the spots that were originally there.Also gave the back of that a good coat of the zinc primer.
Tacked up,plug welded and then seam welded in.Also had to weld a couple of small areas elsewhere on the door where the metal was thin that I hadnt noticed last time
Trimmed it back ready for the lip to go back on.
Thats as far as I got,I was going to make the lip and weld it on tonight but have arranged to go and pick up a new welder tomorrow so will leave it until then to give the new machine a test run.
Cheers Ross.
Edited by rosco454, 08 January 2011 - 09:21 PM.
#143 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 08 January 2011 - 09:23 PM
Cheers Ross.
hi bud, I have had no time to sort out that pm you sent me. I will see what i can do for you this weekend.
simon
#144 rosco454
rosco454
  • 908 posts
Posted 08 January 2011 - 09:27 PM
Not a problem Simon theres no hurry at all,just as and when you have chance.
Cheers Ross.
#145 rosco454
rosco454
  • 908 posts
Posted 15 January 2011 - 08:33 PM
I bought a new welder last weekend.Went for a portamig 211 after reading nothing but great reviews everywhere,I was lucky enough to find second hand but barely used (they guy had only used it once to build a bench and was involved in a bike accident so was selling it on),its only ran about 1-2kg of wire if its lucky so its basically as new.I was looking at a cheaper welder to be honest (clarke 160tm) but when this came along at a decent chunk less than the new price I snapped it up & collected it from west yorkshire the following day.
Here it is.It welds lots smoother and nicer than the old one,really chuffed with it.
As I was too impatient to wait for some 0.6 wire to arrive I got on with welding the door lip back on with some 0.8,this went well apart from a bit more metal to dress off at the end.
Spent a while in the garage this afternoon shaping the lip up and dressing the welds back,also removed the drivers door hinge skin area in the same fashion as this one but no pics.
Going to get some door skins on order and get the other door sorted this week as I have been kindly loaned a door skinning tool and would like to get the doors finished and put out of the way.
Cheers Ross.
#146 rosco454
rosco454
  • 908 posts
Posted 18 January 2011 - 08:49 PM
I got the other door all welded up today,same works as the last one as it was rotten in the same places.No pictures of the work as its just the same as the passenger side apart from a section that needed to be repaired on the lip at the rear of the door where the lock mounts up.I did get a quick picture of the welding on my phone now that I have got the hang of the new welder,much nicer weld and lots less work to clean up.
Cheers Ross.
#147 R.S.P
R.S.P
  • 501 posts
Posted 18 January 2011 - 08:55 PM
some nice work there ross, was good to meet you last week and have a nose at the car, it will be awesome when completed especialy with the standard of work you are putting in to it. :D
#148 mhamps
mhamps
  • 91 posts
Posted 19 January 2011 - 06:02 PM
Really interesting build and great for ideas as the new project I have just bought hopefully going to be a road legal miglia, can’t wait until it is.
Matt
#149 dougie1142
dougie1142
  • 500 posts
  • Local Club: I.M.O.G
Posted 19 January 2011 - 08:53 PM
Progress as ever :) Keep it up, we're all watching!
#150 rosco454
rosco454
  • 908 posts
Posted 19 January 2011 - 10:31 PM
Thanks lads,will hopefully have some more work done later this week/over the weekend.Hoping to get the doors mounted up and trimmed/tweaked for fit before I fit the skins and cut out the centres.
Cheers Ross.
