1380 7 Port Trackday Rebuild
147 replies to this topic
#16 dan_up850
dan_up850
  • 441 posts
Posted 01 April 2010 - 01:54 PM
very very nice mate, dont see enough 7 ports about! well, i havent anyway. top job!
#17 crazycoleman118
crazycoleman118
  • 836 posts
Posted 01 April 2010 - 02:29 PM
looks like a very nice build! you got any date you want it built for?
#18 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 01 April 2010 - 03:03 PM
about august,aslong as its done and all set up by castle coombe action day!!!
#19 josh.evans
josh.evans
  • 1,439 posts
Posted 01 April 2010 - 04:48 PM
nice project you got there mate and my vote goes towards the round front >_<
good luck buddy
josh
#20 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 01 April 2010 - 05:08 PM
Go for roundy with the air filter out of the front of the bonnet! Don't go clubby, won't suit it.
Looks pretty dam nice!
Dan >_<
Edited by mini-man-dan, 01 April 2010 - 05:08 PM.
#21 James182
James182
  • 433 posts
Posted 01 April 2010 - 07:26 PM
Dont go for a clubman front end if your using 10's! it doesnt look right because the front of a cllubman is too long and then tens almost accentuate this? however this is only my opinion!
Great work so far!
James
#22 mini13
mini13
  • 3,811 posts
Posted 01 April 2010 - 07:56 PM
Get a turbo on it. >_<
#23 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 01 April 2010 - 08:01 PM
I like how the brake bias valve is located there, looks neat.
Wish i had the time and money to do a 7port, keep it up.
#24 cossierick
cossierick
  • 24 posts
Posted 02 April 2010 - 05:04 PM
Id go clubby front then youve got a lovley area for a front rad then carbs/filters with direct air flow from the grill.
Plus they do look good on 10's
#25 minitechniquue
minitechniquue
  • 28 posts
  • Local Club: Fylde Minis
Posted 03 April 2010 - 05:37 PM
project looks great what size holes did you drill in your rear frame??? Its going to be one cool mini once finished.... Look forward to seeing more over next few month.
#26 summs116
summs116
  • 372 posts
Posted 03 April 2010 - 06:47 PM
cant remember,i measured all the hole positions then done it with a step drill and kept going untill it got close
#27 summs116
summs116
  • 372 posts
Posted 07 April 2010 - 08:46 PM
Just a little update after bit of work,
fuel tank fitted and pump and filter king
new mk2 rear lights
oil cooler fitted
new modified front brake pipes because when fitted the anti-roll bar the standered pipes hit the drop links on full lock
i going to go 4 the round nose with the air filters sticking the bonnet,but going to put a deflector plate inside the filter to stop direct air ramming into the carbs
#28 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 07 April 2010 - 09:17 PM
What carbs are you going to use, twin webers or bike carbs?
#29 summs116
summs116
  • 372 posts
Posted 07 April 2010 - 09:59 PM
twin weber 45's
#30 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 07 April 2010 - 10:11 PM
Sweet! Webers look so much better.
