#2971
Posted 27 August 2013 - 09:20 PM
#2972
Posted 27 August 2013 - 09:21 PM
#2973
Posted 27 August 2013 - 09:22 PM
Edited by megamini_jb, 27 August 2013 - 09:22 PM.
#2974
Posted 27 August 2013 - 11:07 PM
Got the welding wire changed over and the bottle of gas set up :) Yayy!
#2975
Posted 28 August 2013 - 11:38 AM
put back in the "string" door opener into my MK1 van on the drivers door. exciting stuff ![]()
#2976
Posted 28 August 2013 - 04:15 PM
- Fitted new oil pressure switch
- Fitted new brake lamp switch
- Replaced fuel tank neck seal
- Replaced rear lens foam seals
- Adjusted bonnet catch
- Topped up dash pot oil
- Fitted my shiny new bonnet badge... yeah
#2977
Posted 29 August 2013 - 12:14 PM
Fitted internal fuse boxes, changed driveshaft CV joints, Alubrited ali engine bits, fitted LSD & engine in & mounted ![]()
de-rusted frt grille plate & panel behind the cone filter, etch primed & painted
Edited by MINI MAD RKH, 29 August 2013 - 12:14 PM.
#2978
Posted 30 August 2013 - 09:56 AM
Connected up eng. fitted gear remote, removed sparkplugs & turned over, we have oil-pressure Capn. ![]()
reconnected suspension & fitted wheels - hopefully be test-driving on Sat ![]()
#2979
Posted 30 August 2013 - 04:11 PM
Fitted new/2nd hand window regulator....no more 2 handy up window @ 70mph down the motorway after a fag
#2980
Posted 30 August 2013 - 04:30 PM
The same thing I have done every time I've driven it this week, topped up the water haha. A new rad can't come soon enough!
#2981
Posted 30 August 2013 - 05:59 PM
made a repair panel for my front passenger door and tacked it ok, need to weld it on fully and re skin it now!
#2982
Posted 30 August 2013 - 07:16 PM
Pushed the roll pin back into the gear selector as it had worked its way out, I can now rest assured that I will get 3rd and 4th gear ![]()
I also replaced a missing bolt from the exhaust bracket to gearbox, Hopefully this has solved my oil leak.
#2983
Posted 30 August 2013 - 09:12 PM
Rain-X'd all the windows. Highly recommended when the wipers are so rubbish.
#2984
Posted 30 August 2013 - 09:13 PM
Edited by megamini_jb, 30 August 2013 - 09:13 PM.
#2985
Posted 02 September 2013 - 09:47 AM
Wired up the engine, changed fuel hose, fitted exhaust, added coolant & brake fluid, fitted some fuses, fitted oil press gauge
Started her up to test getting into 1st (was a problem before), drove her out of the garage turned round & put back in the garage all with no footbrake, then bled the brakes ![]()
Oh, then went to MiniFest & bought interior window trim & bonnet grille slat ![]()
Edited by MINI MAD RKH, 02 September 2013 - 09:48 AM.
6 user(s) are reading this topic
Bing (2)
