9971 replies to this topic
#5716 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 19 April 2016 - 07:45 AM
Coolant flush after fitting new water pump.
wait how does that work? you stick it into the water pump, hose it down and it comes out the radiator? if that works for flushing all the coolant then that's mighty cool.
Sorry late reply. Yes works a treat. Need to take the thermostat out first and make sure your heater knob is pulled out fully. This back flushes the system and just keep going until it runs clear.
After that I blew back a little on the rad pipe which forces some water back out the thermostat housing just enough to put a litre of blue coolant in.
Thermostat and pipe back on. Job done.
I don't suppose u know what diameter pipe I would need to do that with. I'm guessing I would need to be a pretty flush fit as to not leak. Also when doing this do u need to drain the system before trying to remove the thermostat or do u just pop the top hose off a catch the little bit of over spill. Sorry for the all the Qs
#5717 crackfoo
crackfoo
  • 304 posts
Posted 19 April 2016 - 09:04 PM
Finished wiring up most of my new loom. Started him up so that was good. Still have the headlights to wire up and spots.
#5718 Nikko
Nikko
  • 125 posts
Posted 19 April 2016 - 09:26 PM
Went to visit and check progress.
#5719 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 20 April 2016 - 06:42 AM
Changed the CTS on my SPi, bit of a git of a job to do too.... most if not all the injection manifold need to be removed to gain access.... also discovered the the manifold heater pipes are full of crud so need replaceing and the heater valve is also FUBAR and siezed up... I did wonder why the heater always blew hot air into the cabin....
Only changed the CTS as the engine is running rich, constantly and over fuelling creating a hesitation and misfire ......
Hopefully sorted now...
Later today, I will be romodelling the centre console as the side parts of it are very worn, but I also want to add switches and a LED digital battery voltage display for the ICE thats installed and for future amps that will be installed...
#5720 Cookiez
Cookiez
  • 205 posts
Posted 20 April 2016 - 08:41 AM
Rebuilding gearbox
#5721 benm
benm
  • 111 posts
Posted 20 April 2016 - 05:07 PM
removed the gubbins out of the rear radius arm bushes, what a state the shaft was in!
NOT looking forward to trying to ream the new bushes
#5722 James_eaton_thewholething
  • 1,063 posts
Posted 22 April 2016 - 12:02 PM
Modifying carbs
2EE51C07-9049-4177-914A-5D5C7977635A_zps
739E965E-703C-479B-B509-D30B7CEA12DC_zps
Got new spindles to order and then those will be filed down to allow better airflow. I enjoy rebuilding carbs
#5723 leepol83
leepol83
  • 1,744 posts
Posted 22 April 2016 - 02:31 PM
Fitted power steering
How do I get big pictures like the guy above?
Edited by leepol83, 22 April 2016 - 02:33 PM.
#5724 bassment
bassment
    Starting My Mini Up
  • 4 posts
Posted 22 April 2016 - 03:00 PM
didnt do anything today but i just received some Force Racing wheels! so happy! :D
#5725 leepol83
leepol83
  • 1,744 posts
Posted 22 April 2016 - 03:08 PM
didnt do anything today but i just received some Force Racing wheels! so happy! :D[/quote
Wow!!!!!!! Now there nice
#5726 ukcooper
ukcooper
  • 1,625 posts
Posted 22 April 2016 - 05:24 PM
Nice wheel are them .
New head light, indicators, grill and cleaned the fog/spot light as stev 220 said. new bonnet lip to be fitted and lined up.
Edited by ukcooper, 22 April 2016 - 05:52 PM.
#5727 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 22 April 2016 - 06:11 PM
put it away in the garage because the carbs playing up and i can't afford a rebuild kit till pay day !!!!  >_<  :dontgetit:  :dozing:  :cry:
#5728 Nikko
Nikko
  • 125 posts
Posted 22 April 2016 - 07:58 PM
[quote name="leepol83" post="3379589" timestamp="1461337683"]
Wow!!!!!!! Now there nice[/quote]
They're beautiful
#5729 1984mini25
1984mini25
  • 8,850 posts
Posted 22 April 2016 - 10:06 PM
A few days a go I replaced the upper steering column bush, witch proved to be a bit of a sod, but was easily sorted with the help of a pair of hammers and a cable tie. Although the new bush did need 'finishing' before fitting with a craft knife. While they were off I stripped and cleaned the indicator stork, making sure all the contacts were nice and clean. Hopefully its now sorted my interment indicator problem were only occasionally the left hand indicators would go on strike. And before refitting I gave the steering wheel and good going over with some shoe polish. Witch has sort of worked to bring it back, but then the steering wheel has had 32 years worth of use.
#5730 mina08
mina08
  • 255 posts
Posted 23 April 2016 - 05:27 AM
managed to find and eliminate 4 rattles
    Bing (1)
