9971 replies to this topic
#5746 dobbin1999
dobbin1999
  • 82 posts
Posted 25 April 2016 - 04:57 PM
[quote name="THE ANORAK" post="3378110" timestamp="1460909715"]
removed the standard mini city stickers. the electric blue was clashing with the cranberry red !!! the start of a process to de-90's the car.
Looks great! Any handy tips for getting off the remaining glue left behind by the stickers? Took my Mayfair stripes off and they've left marks.
EDIT: OOOPS my quote didn't work :/
#5747 dobbin1999
dobbin1999
  • 82 posts
Posted 25 April 2016 - 04:58 PM
White spirit will remove the old glue without damaging the paint.
#5748 SuperDeLuxeNick
SuperDeLuxeNick
  • 625 posts
  • Local Club: West Country Minis
Posted 25 April 2016 - 05:12 PM
Fitted new wheels.
Replaced beading on arches.
Next job is to finally set the ride heights all even and sort stance. Currently sitting way to high on one side!
#5749 davej
davej
    Kelly Jones
  • 985 posts
Posted 25 April 2016 - 06:34 PM
Took it for an MOT and it passed!!  :D
#5750 Chris.Williams
Chris.Williams
  • 679 posts
Posted 26 April 2016 - 07:10 PM
Carpeted my boot/rear of the seat and mounted my ampattachicon.gifimage.jpeg
Then made a boot board, which I will carpet tomorrow all going wellattachicon.gifimage.jpeg
I'll be the first to ask, got any drawings for the boot board? Looks good
Attached File  image.jpeg   44.85K   13 downloads
#5751 Batmini
Batmini
  • 378 posts
Posted 26 April 2016 - 08:03 PM
Thanks buddy, think i'll have a go at one of these
#5752 FAZ
FAZ
  • 284 posts
Posted 26 April 2016 - 08:11 PM
ground the valves in
#5753 Keith Piper
Keith Piper
    Starting My Mini Up
  • 3 posts
Posted 26 April 2016 - 08:39 PM
Cut the floor out
#5754 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 27 April 2016 - 07:03 AM
Cut and retrimmed the centre console to add oil pressure and battery, but to also incoporate a cubby hole too (for somewhere to put my phone)...
I found some stickyback walnut effect vinyl Iv had for years and was just waiting for something to use it on...
#5755 MacGyver
MacGyver
  • 1,028 posts
Posted 27 April 2016 - 07:56 AM
Hammered my left headlight aperture and wing back in to shape and reshaped my arches.
Then my mum came along and said: You really made a pigs ear of that then...
That took the 'satisfaction of a job well done' smile right off my face. 😞
Will have to take it out on the boot floor... 😀
#5756 Chris.Williams
Chris.Williams
  • 679 posts
Posted 27 April 2016 - 11:19 AM
Started wiring my dash board ready for installation
Attached File  image.jpeg   62.28K   11 downloads
Attached File  image.jpeg   37.62K   9 downloads
Bit hard to see but there are 4" speakers in the air vent holes.
#5757 Chris.Williams
Chris.Williams
  • 679 posts
Posted 27 April 2016 - 11:22 AM
Let me know how you get on.
#5758 James_eaton_thewholething
  • 1,063 posts
Posted 27 April 2016 - 03:41 PM
Cut, filed and hammered the exhaust hole to get it to fit up higher.
.F294D82F-C7B2-4537-9C64-3D62B1EA0B8F_zps
61AA1F19-8B4D-47A2-AA56-3882E838122D_zps
#5759 ukcooper
ukcooper
  • 1,625 posts
Posted 01 May 2016 - 01:28 PM
#5760 redboy
redboy
  • 333 posts
Posted 01 May 2016 - 10:49 PM
Coolant flush after fitting new water pump.
wait how does that work? you stick it into the water pump, hose it down and it comes out the radiator? if that works for flushing all the coolant then that's mighty cool.
Sorry late reply. Yes works a treat. Need to take the thermostat out first and make sure your heater knob is pulled out fully. This back flushes the system and just keep going until it runs clear.
After that I blew back a little on the rad pipe which forces some water back out the thermostat housing just enough to put a litre of blue coolant in.
Thermostat and pipe back on. Job done.
I don't suppose u know what diameter pipe I would need to do that with. I'm guessing I would need to be a pretty flush fit as to not leak. Also when doing this do u need to drain the system before trying to remove the thermostat or do u just pop the top hose off a catch the little bit of over spill. Sorry for the all the Qs
The pipe was 22mm. The jubliee clip clamps the pipe. Don't worry about a bit of leakage.
No need to drain the system. A bit of water will come out when you take the thermostat housing off but not much.
    Bing (1)
