Project Pandora
189 replies to this topic
#166 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 21 November 2005 - 11:51 PM
Sorry Pandora, I forgot I was on your section :dontgetit: :tongue:
#167 Pandora
Pandora
    Cadwell Event organiser
  • 1,054 posts
  • Local Club: TMF Lincoln
Posted 21 November 2005 - 11:52 PM
lol no worrys
#168 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 21 November 2005 - 11:59 PM
Ive got a wicked Idea. :grin: How about instead of NOS Vs Turbo. How about Carb Vs Injection :grin: The proofs in the pudding at the end of the day.
#169 mini1071s
mini1071s
  • 115 posts
Posted 22 November 2005 - 12:00 AM
Buy all means hijack, its all got to do with the project. Carry on sir, carry on!
I need some time to write it up, so I will post tomorrow if that's OK? Here are a couple of links to get you started....
http://picasso.org/mjlj/ Megajolt mapped very cheap ignition, built this myself for SU carbed turbo.
http://www.megasquirt.info/ms2/ Megasquirt FAQ. Remember you can't inject the 5 port A series with this unless you use a wet manifold like graham harvey does, (though he uses Emerald - http://www.emeraldm3.../em_ab_em.html).
Fuel injection basics
http://auto.howstuff...l-injection.htm
Get you started anyway!
The SU wins out over the injection on the 5 port because of charge stealing and the fact the injector has to get the fuel in in a very short window with a duty cycle of 62% max unless you use a wet system where the injection becomes just like an electronic analog of the old SU but with an infinately adjustable fuel curve. The entire point of the 7 port head was to allow the superior injection system to be applied to the A series, where you have one port per valve, batch injection is very very simple to implement.
#170 Pandora
Pandora
  • 1,054 posts
Posted 22 November 2005 - 12:02 AM
Thanks for the links.
#171 mini1071s
mini1071s
  • 115 posts
Posted 22 November 2005 - 12:07 AM
No worries. Will do a proper job tomorrow!
#172 Pandora
Pandora
  • 1,054 posts
Posted 22 November 2005 - 12:12 AM
So when is the mag coming out then in 06
#173 ed4ran
ed4ran
  • 2,849 posts
Posted 22 November 2005 - 12:13 AM
Heres my megasquirt!!!
and heres the software (setup for EDIS)
You can change all the fueling, and timing yourself with a normal PC.
and with the lambda sensor its really easy!! :dontgetit:
#174 mini1071s
mini1071s
  • 115 posts
Posted 22 November 2005 - 12:15 AM
Yes!
#175 Pandora
Pandora
  • 1,054 posts
Posted 22 November 2005 - 12:17 AM
Any perticular month. Or still not set?
#176 kada1980
kada1980
  • 608 posts
Posted 22 November 2005 - 08:18 AM
Also to add a wideband will pay for itself, no need for rolling road time unless you want some numbers to talk about in the pub :grin: :wink:
#177 mini1071s
mini1071s
  • 115 posts
Posted 22 November 2005 - 10:33 AM
If I tell you then others will do everything they can to mess it up, so I am keeping quiet until it's printed, sitting in the distrubuters wherehouse and about to hit the shelves! TMF will be the first to know!
#178 Pandora
Pandora
  • 1,054 posts
Posted 22 November 2005 - 04:44 PM
Well thats fine by me lol :dontgetit:
#179 Engine_tuner
Engine_tuner
  • 35 posts
Posted 22 November 2005 - 07:23 PM
Sorry for the late reply guys,
There seems to have been a few more pages added since i last checked?
The orange mini with the sequential box is owned by Nigel Hepburn (check my website)
I built the engine (full race 1380cc with a 38x32mm off-set head) and Mike (MBE) supplied the sequential box.
This runs fuel injection on the 5 port head & Webber alpha ignition with very good results, As do many other serious sprint drivers.
BUT the fuel injection system thats works on a 5 port head is very expensive.
So far i have found a 7 port head using carbs has very little gain over a 5-port.
#180 Pandora
Pandora
  • 1,054 posts
Posted 22 November 2005 - 07:56 PM
I dont know what to do anymore so much info about the near to none improvement over a 5 port lol talk about mella drama, i think i should become a writer for eastenders or something :dontgetit: (erh yeh right!!!)
It seems to me, im going in the wrong direction with all this. A case of (me see, me like, me want) well i will have to think long and hard. Many thanks to everyone for their ideas.
