Florence My '97 Cooper
#376
Posted 17 February 2012 - 11:40 AM
#377
Posted 17 February 2012 - 11:43 AM
Just done 52000 miles since 1983 haha and an an enging strip/ piston clean up and general engine cleanup about 4000 miles ago.
#378
Posted 17 February 2012 - 11:57 AM
#379
Posted 17 February 2012 - 12:08 PM
Pink door cappings might cure it !
Obviously the solution
#380
Posted 17 February 2012 - 12:54 PM
#381
Posted 17 February 2012 - 02:22 PM
#382
Posted 18 February 2012 - 04:00 PM
Considering it's an MPI, a K series engine swap would be much more straightforward
Haha swap rattle and noise for HGF and curious water evaporation and vaccum filling problems! Fun times.
#383
Posted 18 February 2012 - 04:11 PM
I've bought some wheels for some reason
Edited by bcjames, 18 February 2012 - 04:12 PM.
#384
Posted 18 February 2012 - 05:26 PM
Pepperpots by bcjamesmini, on Flickr
Really nice driving her again now she's sort of working. Still no parts ordered for the big fix! As yes undecided, it's a big bunch of money for what feels a small problem. But the compression is escaping in to my crank case
Mini Cooper by bcjamesmini, on Flickr
#386
Posted 18 February 2012 - 07:55 PM
All the little issues seem to come down to a slight lack of power. Being winter, and I work outside, I've been driving with lights, heater, cd player, wipers etc. on, so with that slightly idle issue coupled with the demand, it was making the engine feel like it was running terribly. The idle tweak has certainly helped.
The compression test gave, if I remember correctly, 200 +/- 10. The leak down test showed I am losing past the rings, especially on three and four. That's why I had to reroute the breathers, the engine is just throwing out mucky air from it's breathers.
All the sensors etc check out okay. Normal maintenance has been done, oil, plugs, leads etc. So I'm hoping the engine rebuild will solve that. It's just a matter of how far to take the rebuild!
I do like the Rover Pepperpots on the late Sevens. Made by Speedline too
#387
Posted 18 February 2012 - 08:06 PM
When I did a leak down test on the top end the highest I got was 19% on CLY 4. Lowest I got was 12% CLY1. CYL2 and 3 were about the same at 15% and 14% respectively. I believe a fresh engine gives a nominal 8%...
I also did a pressure test and got 1/2" on the scale.
So overall, it's a pretty healthy MPi :) Did that all when I first got the car, and I've done 3000 miles since. So it's still going pretty well.
Hoping yours gets better after the rebuild!!
Simon.
#388
Posted 18 February 2012 - 08:11 PM
Naivety can be a good thing at times I suppose
The wheels have a bit of curbing damage, but I might get them sorted. I wasn't sure when I bought them, but everyone I have showed them to seems to like them. They are 4.5in so would go on just as my Minilites come off, if I do it.
#389
Posted 20 February 2012 - 02:03 PM
Preview of “mini engine spec.xlsx” copy by bcjamesmini, on Flickr
I've realised I am going to have to sort the oil leak myself now. I know I need the seals for the clutch end of the crank, but I don't know what I need there so can anyone advise?
If the rattle is emanating from the drop gears, I'm going to need to replace those too
#390
Posted 20 February 2012 - 02:16 PM
http://www.minispare...id=36593&title=
States it does not include the clutch oil seal. Would purchasing one of these:
https://www.minispar...ty=pb&pid=35719
see me right as far as gaskets are concerned?
