Mini Virgin Rebuild Of 83 Mayfair.
#751
Posted 06 January 2013 - 05:20 PM
#752
Posted 06 January 2013 - 05:22 PM
#753
Posted 06 January 2013 - 05:42 PM
#754
Posted 06 January 2013 - 08:02 PM
Graham
#755
Posted 06 January 2013 - 08:04 PM
#756
Posted 06 January 2013 - 08:29 PM
#757
Posted 06 January 2013 - 09:39 PM
#758
Posted 07 January 2013 - 07:12 PM
#759
Posted 07 January 2013 - 08:31 PM
Hugh
#760
Posted 07 January 2013 - 10:34 PM
you do make me laugh, shiny bolts but all still in bits overall, unpainted lol. As for shint bolts, hours spent with a wire brush grinder attachment, being very boring. Just cant bring myself to putting rusty bolts on. Maybe if I wasn't so fussy I would have done it all by now !! Still haven't timed it, hate learning new jobs, always nervous of messing it up but I suppose I have to take the plunge.
Graham
#761
Posted 08 January 2013 - 08:54 AM
#762
Posted 15 January 2013 - 08:02 PM
another small update, firstly the crud turned good stuff. Got an internal bonnet release off fleabay, rusty, stiff but complete.
wire wheel as usual and kurust sorted it and added a little paint. I soaked the ends of the cable in wd40 which freed it up nicely so all ready to go.
Also did the handbrake lever and surprised Matthew with an allot handle, he was well chuffed.
I wanted to test fire the engine with the cooling system in place but on the fleabay set I won the heater matrix hose diameter was too big so I will be reselling those and buying a new set, probably a good idea to be honest, this was the state of the connecting tube from bottom hose to heater.
Will be putting in a plastic connector in the new set.
So back to the engine, rapidly turning into a right pain and following Hugh's great pictorial PM on statically timing an engine I timed it to 6deg btdc.
Used a multimeter to check when the points opened and moved the dizzy round till the had just opened and clamped the retaining bolt tight.
Rotor arm pointing to No.1 piston as is correct I think, but it doesn't really matter if you put the plugs in the right place I think.
Then the fun started, Jan went shopping so I moved my Focus to the porch door and dragged the engine through the house to the front door, there it was attached to the jump leads.
I have used the solenoid to switch the power from the focus to the engine to learn how it worked and stop sparking. It turned over nicely, no clunking or scraping so I think I have put it back together ok. This was a dry test to check the starter would spin the engine, no plugs etc and no oil, just the build lube and wd40 for extra protection. It was a very quick test as I didn't want to run it dry for long until I can get oil in it and get the pressure up.
The problem I have found though is that the starter teeth didn't disengage fron the ring gear until I turned it using a socket. Maybe it needs the engine fired up to throw off the teeth, I'm not sure, I have asked in the tech section and will report back. All going fine though, last few bits being picked up Saturday.
And if anyone tells Jan I was testing the engine in the hall, I will not be your friend anymore, lol, I have to break her into the test firing phase slowly as it may well have to be done there due to battery power needed. All tidied away before she returned so got away with it!!!
Not very exciting but getting there,
Graham
#763
Posted 15 January 2013 - 08:15 PM
Are they not getting red hot?
#764
Posted 15 January 2013 - 08:18 PM
#765
Posted 15 January 2013 - 08:21 PM
The feed wires no, but the engine earth yes, very quickly, so put another in parallel, but could do with some thicker wire as you suggest !! Did for the test though but point taken.
Longer jump leads?
