My Engagement Ring
1514 replies to this topic
#166 grahama
grahama
  • 2,442 posts
Posted 15 July 2012 - 06:07 PM
Hi Carlos,
tricky repair by the look of it. How do you get your welds that 'oblong ', mine are all round when pulse welding. How are you going to clean up in the gutter, looks a bugger to get discs to !!
Graham
#167 Carlos W
Carlos W
  • 10,115 posts
Posted 15 July 2012 - 06:10 PM
It's not my welding, it's my mates!
But, he moves the welder from left to right whilst pulsing!
The spit made it easier to change the angle and get the grinder in!
I'll get a pic of it ground back!
#168 TURBO-TOM
TURBO-TOM
  • 50 posts
Posted 15 July 2012 - 06:14 PM
your mini is looking good mate, looking forward to see how it comes along. it will be a nice little car when your done, keep up the good work.
#169 Carlos W
Carlos W
  • 10,115 posts
Posted 15 July 2012 - 06:18 PM
The problem is, the Mrs is on nights next weekend, and the bedroom is above the garage, so I can't make any noise or it keeps her awake, the weekend after I'm in Newcastle, and the one after that I'm in Cambridge!
I may get in on Friday afternoon and plug weld around the rear wheel arch
#170 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 15 July 2012 - 06:50 PM
Glad to see that roof corner went to good use :thumbsup:
#171 Carlos W
Carlos W
  • 10,115 posts
Posted 15 July 2012 - 06:51 PM
It took a bit of fiddling, but far easier than fabricating my own
#172 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 18 July 2012 - 03:05 PM
Carlos roof repairs are a nightmare. Getting the torch down into the corner is nearly impossible. Looks good.
Hugh
#173 Carlos W
Carlos W
  • 10,115 posts
Posted 18 July 2012 - 04:16 PM
Thanks Hugh, next task is to get the car out the garage, sweep the car out then turn the car around so the other rear 1/4 can go on
Also trying to sell a few bits on Ebay as I'm short of cash!
I've had the car 2 years next month!
Scary
#174 grahama
grahama
  • 2,442 posts
Posted 18 July 2012 - 09:22 PM
I didn't know I had had mine for two years till a member told me!! Time flies when you're having fun!! Would give u a hand if I was closer pal, but I'm sure you'll be all welded up soon.
#175 Carlos W
Carlos W
  • 10,115 posts
Posted 19 August 2012 - 08:33 AM
Finally got into the garage yesterday got the mini out to turn it around, swept the garage floor and had a bit of a tidy up.
Then cracked on with the near side rear 1/4
Pulling the edge in tight whilst plug welding down the front edge
It fitted far better than the other side.
Then we went out to a bbq and had a few strongbows.
I need to fix the handbrake on the Mazda today so can't get back into the garage, and the wife is on nights next weekend so once she's up I'll go down and use the last of the welding gas up which isn't enough to finish the job off but I'm too tight to order a new bottle until I've used what's in this one.
Next to buy is
Inner wings
Outer wings
Front Panel
Solid front subframe mounts
I'm going to go with a genuine front end, as everyone says they fit much better.
#176 grahama
grahama
  • 2,442 posts
Posted 19 August 2012 - 04:13 PM
Hi Carlos,
rear qtr looks to have gone on really well, a nice job. The spit pole does look a funny angle though, mine is horizontal through the mini and it spins straight. Does your set up spin to give you more room in a particular area or is the supports each end different heights??
Graham
#177 Carlos W
Carlos W
  • 10,115 posts
Posted 19 August 2012 - 04:18 PM
Hi Graham, the drive is on a bit of an angle so it makes the pole look worse.
The car naturally wants to sit the correct way up.
The supports are both the same height.
Another day at it and that 1/4 will be done!
#178 Brams96
Brams96
  • 2,308 posts
Posted 19 August 2012 - 06:00 PM
Good progress Carlos, wish I could say the same!
#179 Carlos W
Carlos W
  • 10,115 posts
Posted 19 August 2012 - 06:10 PM
I don't know where the time goes Scott!
I've had the car for 2 years now.
I had a sense of actually getting somewhere yesterday when the panel went on fairly easily.
Just been pricing up half inner wings, solid front subframe mounts and a genuine front end, not much change out of 500 quid!
#180 Brams96
Brams96
  • 2,308 posts
Posted 19 August 2012 - 06:15 PM
I'm too busy with OT at work, house work & trying to sort little problems with my father in laws motor home at the moment. I've been in the garage 4 times in the last month, just to put something in there then carry on. I'll probably get time . . . during winter! :(
Edited by Brams96, 19 August 2012 - 06:15 PM.
