My Engagement Ring
1514 replies to this topic
#136 Carlos W
Carlos W
  • 10,115 posts
Posted 07 May 2012 - 02:53 PM
I've had a really busy weekend, unfortunately, not involving the mini.
Saturday I stripped the brakes on the wifes car as she said it was making noises.
The car is 3 years old with 33k miles and full service history, obviously the full service doesn't include taking the brakes apart, cleaning, greasing and putting them back together. Anyway, in the afternoon we went to a mates for a birthday party so that was a good laugh.
Then yesterday we had people coming round for Sunday roast so I spent all day slaving over a hot stove.
Today however, I got into the garage for a major sort out! A mate of mine has agreed to store the doors and glass so I've got more room! I've then re-arranged all the boxes of bits and pieces, cleared the work bench and......
Mounted a vice.
I put the hubs in, and managed to get the ball joints undone, and removed the pins that go between the hubs and the steering arms!
I'll get these bits painted up this week!
#137 Brams96
Brams96
  • 2,308 posts
Posted 08 May 2012 - 05:25 AM
Cracking on, good stuff. Must be nice to be able to see your bench again ;D
Edited by Brams96, 08 May 2012 - 05:26 AM.
#138 Carlos W
Carlos W
  • 10,115 posts
Posted 08 May 2012 - 08:54 AM
The bench is well lit too! ;-)
I have some more tidying up to do, then i'll have loads of space to work!
Next challenge is to remove the bearings from the upper arm, I might as well replace them!
#139 Carlos W
Carlos W
  • 10,115 posts
Posted 19 May 2012 - 06:11 PM
I'm enjoying painting bits
Tomorrows task is to look at rear 1/4 panel fitting
Edited by Carlos W, 19 May 2012 - 06:12 PM.
#140 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 19 May 2012 - 08:51 PM
Carlos they look edible!! Of course you cook your parts!
Hugh
Edited by hughJ, 19 May 2012 - 08:52 PM.
#141 Carlos W
Carlos W
  • 10,115 posts
Posted 19 May 2012 - 08:54 PM
Thanks Hugh,
I've just remembered, there's the rear valance closing panel to put in before trial fitting the rear 1/4 tomorrow!
When I think about it, there's only 2 rear 1/4s, sills, 2 inner wings, a front end, and that hole in the roof to do, then the shell is done!
Ha Ha Ha
#142 Carlos W
Carlos W
  • 10,115 posts
Posted 20 May 2012 - 06:26 PM
Today was a day of mixed emotions!
After deciding not to go to L2B due to the rubbish weather forecast it was time to crack on with the car!
The rear valance closing panels were cut in two then fitted in two pieces!
Then came to rear 1/4 fitting and it was nowhere near where it was meant to be! The car has been involved in a rear end crash at some point, and everything involving the offside rear corner has been a nightmare.
Anyway, after about 6 hours of clamping, some cutting, spot welding etc we have this
Still needs ground back
Plug welds need dressed still
It looks like a car again!
#143 grahama
grahama
  • 2,442 posts
Posted 20 May 2012 - 06:46 PM
Looks like a good job to me Carlos !!
Have you cut the panel to fit the frame, or the frame to fit the panel. Is there any creasing in the shell or are we talking small amounts out, but annoyingly hard to fit round??
How much bodywork left Carlos??
Graham
#144 Carlos W
Carlos W
  • 10,115 posts
Posted 20 May 2012 - 06:52 PM
Small amounts out, the wheel arch didn't line up too well!
There are no creases in the panel though, adjustments weren't that extreme
I'm going to de-seam it so there will be a skim of filler here and there!
It will all be welded from the inside, then cut the lip off!
This is going to take another half day to finish, then there's the other rear 1/4 to do, inner wings, front end, hole in roof and sills!
I cut the old inner wings off today too, it has made some extra room in the garage. I remembered to remove the vin plate before chucking the wings in the scrap pile!
#145 Carlos W
Carlos W
  • 10,115 posts
Posted 06 June 2012 - 08:43 PM
I went into the garage yesterday, severely hung over! I drilled holes in the wheel arch lip in order to plug weld to the rear 1/4, I welded them up and it just kept popping off!
So I gave up!
I went down after work today and welded the inner seam where the rear 1/4 meets the rear panel in order to prepare for cutting the lip off which I will do at the weekend
#146 kcchan
kcchan
  • 874 posts
Posted 07 June 2012 - 12:15 PM
Your doing a good job, keep at it!
#147 Carlos W
Carlos W
  • 10,115 posts
Posted 07 June 2012 - 07:19 PM
Thanks!
I'm changing my shift pattern over the summer to work 9 days a fortnight instead of 10 (compressing my hours) so hopefully this will give me a bit more time.
#148 Carlos W
Carlos W
  • 10,115 posts
Posted 09 June 2012 - 02:46 PM
Tasks for the weekend include the mini and doing some touching up of paintwork in the bathroom
This morning was spent on the mini.
I roughly took back the welds where the rear 1/4 was fitted
Then started the deseaming
Then working my way upwards
There's a lot of filler, confirming the rear end damage at some point.
Unfortunately, I've run out of welding wire, and I'm running out of gas! I want my money for the Brands Hatch Mini Festival so welding wire will have to wait!
I also need some flexible sanding discs.
It's all about the money
#149 Carlos W
Carlos W
  • 10,115 posts
Posted 30 June 2012 - 04:40 PM
OSR quarter deseamed now, it needs sanded with flexible discs to remove the harshness of the grinder, then a skim of filler and all will be wonderful!
Next task, fix the hole in the roof!
#150 grahama
grahama
  • 2,442 posts
Posted 30 June 2012 - 07:37 PM
Hi Carlos,
nice work, agree a bit of filler and it will be mint, and according to the site UPOL Fantastic is the stuff to get, (not like me, doh !! ) Comming on a treat, is the other side done already, can't remember?
Graham
