My Engagement Ring
1514 replies to this topic
#1366 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 June 2018 - 05:06 PM
More prep today.
Primer on
Then primer flatted
Some bits primed
Bonnet flatted
:w00t:
#1367 Carlos W
Carlos W
  • 10,115 posts
Posted 19 June 2018 - 05:11 PM
He's on fire.
Anything major to worry about?
#1368 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 June 2018 - 06:27 PM
The boot lid needs work but all else is fine
#1369 jamesquintin
jamesquintin
  • 1,025 posts
Posted 19 June 2018 - 06:29 PM
jesus thats fast! What grit paper do you use? how many grades do you go through? Is it all with sanding blocks or a DA..?
Q
#1370 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 June 2018 - 06:35 PM
Q
I have flatted the primer with 400grit discs on blocks and an orbital sander however, I will go back over with 600 before paint to reduce the pig tails from the orbital sander and the scratches from the block sanding.
The 400 is just to get the primer flat and shaped
The problem with basecoat is that it doesn't fill any imperfections. You can get away with more with some colours but colours like this and silvers need A1 prep
#1371 Carlos W
Carlos W
  • 10,115 posts
What's wrong with the boot lid?
Have the rubber boots arrived?
#1372 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 June 2018 - 06:37 PM
Rubber boots arrived.
Boot lid has some filler edges showing through the paint. No biggy, Ill just block it and re-prime
#1373 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 June 2018 - 08:21 PM
Holes for rubber loom boots are cut
Here are the boots, for a Mk2 Golf tailgate
Hole marked and cut
And boot fitted
I think it may need sticking in though as the A post is 3 skins thick and the boot is only designed for 1 skin
I was going to start painting it today but my spray booth needed some TLC and what started off as a simple job of changing the filters ended up being a full deep clean and re seal. It really needed doing and i thought it would be wise to do it before the respray to minimise any trash in the paint.
Anyway, got that done and pushed the Mini in along with some of the parts ready to go.
First on the agenda tomorrow after a mask up is to paint the exposed interior panels
And the the roof
Ill prob paint the arches and grille first with the interior
#1374 Carlos W
Carlos W
  • 10,115 posts
Posted 26 June 2018 - 08:29 PM
I literally love it
#1375 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 June 2018 - 08:58 PM
I can't wait to get some colour and shine back on it.
#1376 Steve220
Steve220
  • 5,137 posts
  • Local Club: BMC
Posted 26 June 2018 - 10:42 PM
Glad people are following suit with the door grommets!
#1377 Carlos W
Carlos W
  • 10,115 posts
Posted 27 June 2018 - 11:13 AM
I literally cannot wait for the next update
#1378 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 27 June 2018 - 11:52 AM
Follow all of ben's work. its amazing how easy he makes it look. Top work as always and i love the updates.
#1379 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 June 2018 - 05:09 PM
Everything ready for the first lot of painting
And done
Its a really interesting colour in that it changes alot depending on the light.
Here it is on the ariel in semi sunlight inside the workshop
I then re-masked ready for the roof and bonnet
You will have to wait for the finished photos as I am going to have to re-paint the roof. Someone opened the service door on the booth mid way and the extractor pulled a mist of dust straight across the booth  :xxx:
#1380 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 27 June 2018 - 05:21 PM
That is going to look soooo good :wub:
