7port 1293 Spec Engine
362 replies to this topic
#121 danny1
danny1
    In the navy you can sail 7 peas
  • 1,321 posts
  • Local Club: bumpstart
Posted 14 April 2011 - 05:26 PM
i live in cornwall mate.
that would be wicked mate
i got these tiny little 8mm long thred spark plugs for the 7 port head there the only ones that will fit the med 7 port head
im pritty sure ill need to change the chokes and jets in the webers as they will be to big
#122 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 14 April 2011 - 05:40 PM
i got lots of jets and chokes 4 webers,i had them in mine so i had slarks drill it out to 10mm plugs,
get a spare set in,
when you about,i can do sat afternoon,sundays
pm me your address / phone number
Edited by summs116, 14 April 2011 - 05:45 PM.
#123 danny1
danny1
  • 1,321 posts
Posted 14 April 2011 - 07:45 PM
i seen you live up bristol might be easier if i still put the 5 port on get some miles on it so ist not as tight and then come up to you so its not so much of an inconvience for you travel all the way down to cornwall.
just an idea
#124 danny1
danny1
  • 1,321 posts
Posted 15 April 2011 - 11:51 AM
righty been thinking with the 5 port head thats going on, may have a slight issue, because of my silly dry decking kit ahaha
i can block ot of at the block because of the holes that were drilled so looks like im gonna have to make a plug up to fit,
if only i had a lather sop i could make one up grr
#125 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 15 April 2011 - 01:36 PM
what about two grub screws for the time being? might make things easier
#126 danny1
danny1
  • 1,321 posts
Posted 15 April 2011 - 01:46 PM
nah because im not putting a cor plug in because i have my dry deck adaptor there
#127 summs116
summs116
  • 372 posts
Posted 15 April 2011 - 03:50 PM
has the holes in the block been blocked up or are u using specail head gasket,if the hose are still there just fit the pipe on the block and put somthing solid in the other end and clamp it up,or u can get rubber hose end caps
#128 danny1
danny1
  • 1,321 posts
Posted 15 April 2011 - 06:32 PM
no my cylinder head has no water ways at all, so i can run a standard head gasket, and i dont have to cap of my water ways on the block or use a special head gasket
what ill do is find soemthing big enougth to clamp in one end of the dry deck pipe which should stop the water coming out
#129 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 15 April 2011 - 06:42 PM
bit of a bummer about not getting it set up... recon it will still be done before riv run?
#130 danny1
danny1
  • 1,321 posts
Posted 15 April 2011 - 06:47 PM
ill have the car driving by riv run for sure, just not 7 portr power 5 port fart power, ahh well.
after the month ive had at work i need some down time, got premoted begging of the month, and had 2 new baby chefs join my boat which ive taken under my wing, probllem is ive seen spoons sharper.
one of them last week decided to poor cream over me by mistake and the outher one is lazy. thank god there both on leave, and i wont see them till half way through next month because ill be on leave and doing a level 3 first aid course.
but got 2 weeks of so ill spend 2 days getting the mini running and the rest of the time enjoying myself
#131 mini93
mini93
  • 8,615 posts
Posted 15 April 2011 - 07:03 PM
so i wont get to look at this ere head? >_< drats!!
should still be good to see it though
#132 danny1
danny1
  • 1,321 posts
Posted 15 April 2011 - 08:41 PM
ill bring the head the riv so you can have a gander and ill show you how stupidly small the plugs are and how awkward the little s**t's are
#133 danny1
danny1
  • 1,321 posts
Posted 21 April 2011 - 04:43 PM
right my 5 port head is ready just need to clean it up a little bit tomorrow but then jobs a good en, so fingers crossed ill get it running maybe tomorrow as ill use my snap on gun to get the 7 port head of and then slide 5 port head on do my tappets and then plumb it all in nice and easy :unsure:
#134 danny1
danny1
  • 1,321 posts
Posted 22 April 2011 - 05:42 PM
right well heres the good news
the mini started today, ran really nasty on my first hiff 44, was running way to rich and back firing through the carb, so we switched it of and put anouther one of my hiff 44's on and its running like a dream, same carb i used on my 1380.
was so chuffed, was just about to take it for a spin when i noticed no oil pressure what so ever.
so switched it of.
ive hear no grinding noises nothing like that, havnt run it but ive checked oil cooler which was empty, i checked my pressure relif valve thingy and its dry.
just looks liek no oil was being transfered from the sump to the rest of the engine, so after alot of reading and thinking, the only thing i can put it down to is, that stupid little o ring between the gear box and engine.
so looks like ill be pulling my engine out of my car tomorrow and stripping my engine, to say im upset is an understainment.
oh and ive had to change the starter motor, im using a verto starter with the solenoid attached, my lightened fly wheel has the wrong ring gear on it, so solved the probllem of why it wouldnt crank over
#135 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 23 April 2011 - 10:11 AM
Engine out again. I know exactly how you feel.... :) Did you spin it over with the plugs out to check the oil pressure before you started it? If the preasure was there then it might just be a matter of putting some oil down the hole in the front of the block where the pipe for the filter comes off and pushing the car backwards while its in 4th gear. This would prime the pump and get rid of any vacuume that may be stopping your preasure. Hope its something simple and every thing is ok in the engine. You would be amazed how quick the bearings wear when they dont get oil.
