7port 1293 Spec Engine
#136
Posted 23 April 2011 - 12:16 PM
#137
Posted 23 April 2011 - 06:39 PM
right well its all sorted and she runs with a nice high oil pressure
well started teh day by pulliugn the engine out stripping it and rebuilding it with fresh gaskets as the little o ring waqsnt selling, could tell when i tuck it apart as as could see were iot had been suckign air.
any wya put it back in teh car got everythign connected fired her up and 0 psi of oill pressure again
so pulled it back out again and stripped teh clutch end and checked my oil pump, it was primmed and ready, only issue was id put the stupid gasket on upside down doh, XD
so put a new gasket on and youll never guess what
well over 100 psi of pressure.
i feel like such a tard, checked the oil and the engine when it was apart, looks like the pump was getting oil to the important bits it was just doing a shoicking job.
so fingers crossed shell be ok, gonna take it nice and slowly with her till shes propperly run in.
just got to get my timmiing light on her tomorrow and change the needle and shhell run nice and sweet
#138
Posted 24 April 2011 - 07:14 AM
#139
Posted 24 April 2011 - 10:05 AM
#140
Posted 24 April 2011 - 04:32 PM
right ive got it running but its ildes at 1500rpm and i cant get it any lower 1500 is the lowest i can get it to before it dies.
ive tried every thing tappets, dizzy, 3 carbs 2 inlet manifolds and 2 exhaust manifolds nothing is making it better, is there soemthign im missing, its really getting me down now, as if i set it to 1000rpm it kindad starts but its like its hunting for the idle , and its dead ropey, like the whole engine is shaking, its not normal.
now im thinking is this because of my 649 cam? and my 1.5 rockers and i set the tappets at 15tho
im in need of some desprete help on this ive spent 10 hours tryign to sort it today and it just feel like ive had my bum spanked with a metal pole,
has any one else had issues with trying to set the idle on there car after a rebuild
ive also had to put the mechanical fuel pump back on as my facet and pressure reg were to harsh for it and were over fueling it :/
#141
Posted 24 April 2011 - 07:50 PM
#142
Posted 24 April 2011 - 10:33 PM
#143
Posted 24 April 2011 - 10:44 PM
I'm assuming you've been trying to set it up once the engine's properly warm??
#144
Posted 24 April 2011 - 10:57 PM
well my mates idles at 900 rpm and thats a 649 cam in a 1400 a series engine
i think i know what it is so gonna check tomorrow, and fingers crossed
#145
Posted 25 April 2011 - 07:56 AM
#146
Posted 25 April 2011 - 10:42 AM
although your mates idles at 900 with a 649, I think you will have trouble achiving it because, you are 100cc less than his, The 7 port intakes are HUGE so gass speed will be crap at idle,
also if you have a mega light flywheel it can affect things.
that said try upping the running idle timing to about 18 deg, thats where mine likes to run.
#147
Posted 25 April 2011 - 09:37 PM
we have lift of!
got it running today and idling at 900 rpm, what it seems to of been was when i first tried to set teh car up on my aldon dizzy i got a horrible back fire and it wouldnt rev, so i swaped for my mpi one, which got it reving nice but wouldnt idle.
to cut a long story short, i was right with my aldon dizzy as it has the right curves for my engine, but my braided oil pressure pipe wasnt allowing me to get enougth swing on the dizzy, so ive had to remove it and put my little elce sender like on a standar car back in and modify it with my die grinder. but car is running nice.
cam is horrible to drive on, i will say that now wish id put something not so harsh in, as trying to run it in is hard because as soon as it comes on to the cam i have to change gear, and its just not giving me any power, im finding my self bouncing down the road all the time. but once you hit that limit and the cam kicks in, its like driving a tottaly diffrent car.
but on teh drive back from my work shop to my house i manged to shake my rocker cover lose and spray oil every were but ive fixed that, and the engine has tried to snap the engine steady brack from the bualkhead, so got that to fix tommorrow or wednesday, who knows.
but im so happy its all over
#148
Posted 26 April 2011 - 10:05 AM
#149
Posted 26 April 2011 - 11:55 AM
#150
Posted 26 April 2011 - 04:50 PM
yeah its horrible to drive atm as its just so lumpy and i cant put and power down as im running it in.
oh and i managed to get a ride on a tow truck this morning :/
the bloody engine snapped my engine steady brack clean of at the bualk head. so got home got the welder out welded a heavy duty plate in its place, and fitted 3 more engine stedies, down side to this is that it vibrates so much, i dont like it much but im sure the misses will enjoy it.
outher than that ive just be driving all day trying to get some miles on it
oh and ive worked out why shes a bit smokey, when i used the head last i noticed valve seals were rubish, of course ive forgot to change them hence her smoking, so ill wait till riv has been as ill pick up a copper head gasket, and ill do it next week as i have a set of new valve seals in my room some were
