The Great Estate
#76
Posted 02 April 2006 - 06:55 PM
#77
Posted 07 April 2006 - 06:08 PM
Doing something______Manifold nuts!________Job done!____________Gently placed in boot
#78
Posted 07 April 2006 - 06:32 PM
#79
Posted 07 April 2006 - 07:31 PM
look how dirty I am! I was wearing CV grease as hair gel!
It's gonna be ace when it's finished!
i think his hair is finished, thats the look hes going for
#80
Posted 14 April 2006 - 09:54 PM
front end has been covered with a few layers of this filler primer, just a bit of light sanding then it'll have a few layers of proper primer then topcoat!!
Also stripped my engine down a bit! Took all the stuff on the outside off (water, oil and fuel pumps, slave cylinder and all other brackets and stuff) rocker assembly, head, flywheel housing and diaphragm are now off as well! Going out to get a flywheel puller tomorrow!
Dished pistons? Standard? also bit worried about the fact that it looks like the valve has been hitting the piston
Would you say this head has been recon'd 200 miles ago like i was told?#
diaphragm doesn't look too old though
apologies for the amout of pics!
#81
Posted 14 April 2006 - 10:03 PM
#82
Posted 16 April 2006 - 10:26 PM
#83
Posted 25 April 2006 - 08:18 AM
wow im slow! looking good pooky hows the engine coming along?
found a yellow yet?
paints4u.com ?
doesnt have colours but loads of types of coatings
#84
Posted 25 April 2006 - 07:53 PM
looking look there matey keep up the good work - the bulkhead is to die for!!
#85
Posted 25 April 2006 - 09:20 PM
Xr2i seats will be comfy in any car ford always make comfy seats! i know mine are.
found a yellow yet?
paints4u.com ?
I keep forgetting about parts I've got! Yeah can't wait to get the seats fitted, i think they might be a bit high though, we'll see but may have to redesign the subframes.
Not fully decided on a yellow new MG trophy yellow and old MG Inca yellow are high on the list, as is 106 GTI and even smart car yellow
haha I do like the large hammer conveniantly placed near the engine.
Yeah it came in handy in persuading the flywheel and housing to come out!
Soon start the arduous (spellin') task of rubbing down before topcoat. Bulk head will probably be the paint test area. I'm spraying it first so i can crack on getting the subframes and suspension components in...
#86
Posted 04 May 2006 - 09:59 PM
Just been having a closer look at my crank+conrods (deciding whether to take them out) when i noticed a few things!
Red arrows - Definately looks like its been ground down here and another place, was this done in the factory or could i have a balanced crank?
Blue arrows - Numbers scored into the big ends. Again was this factory or could someone have inspected these in the past?
Green arrow - bit of green paint on here and on other parts of the crank. What's that about?!
Any idea?
#87
Posted 04 May 2006 - 11:39 PM
Does anyone happen to know what the metal plate that's screwed into the spare wheel well cover is for? I have no clue!
I might - which plate is it exactly - send me a pic.
Jae
http://www.podnuts.com
#88
Posted 20 May 2006 - 12:53 PM
Got it on its side to have a go at some welding to the floorpan and sills. (nerve wracking! lol) and now its leaning up against my cupboards so I can't get at anything
again
The worst part was around the rear jacking point but cut and grinded for a while and treated areas to some kurust until ready for welding. Made sure i didn't forget the inside
So got on with the welding of the floorpan replaced the jackstand with a new one from M Machine and gave it a coat of red oxide
I'll get on with welding the sill after L2B
#89
Posted 20 May 2006 - 01:38 PM
Did you know though that the bit that you call the jack stand isn't that at all. it is what they used in the factory to hold the shell to the dolly. i think that they can come off altogether to be honest
#90
Posted 20 May 2006 - 01:41 PM
Miniboo soo wise
