Post Your Fast Road 998 Specs
67 replies to this topic
#31 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 03 February 2014 - 08:56 PM
Latest......
MG head
MG cam
998 Mini City E Distributor (8 deg) modified
HS inch and a half carb
Howley Inlet
1.3 Metro air filter
Electric fan
1.3 Metro cast exhaust manifold
Modified 1.3 Metro exhaust with single back box
Lightened Flywheel
Metro gearbox
3.76 Diff
Sort of budget,  insurance friendly,  fast road :whistling:
What bhp?
Cant afford rolling road sessions, I do it with a stopwatch between marked lamp posts on a straight bit of road near me.
Its quicker than it was and will keep up with a 1275  to 70mph, low diff helps and I recon its about 50.
Nice thing is that it revs a lot and sounds lovely, cant get better than that on a budget
#32 coopdog
coopdog
  • 4,506 posts
Posted 03 February 2014 - 09:37 PM
Latest......
MG head
MG cam
Howley Inlet
Electric fan
Lightened Flywheel
Metro gearbox
3.76 Diff
What bhp?
Very accurate hahaha
#33 minimender
minimender
  • 1,589 posts
Posted 03 February 2014 - 09:40 PM
Latest......
MG head
MG cam
Howley Inlet
Electric fan
Lightened Flywheel
Metro gearbox
3.76 Diff
What bhp?
Will add that it keeps pace with my mates 1968 998 Cooper easy enough :)
#34 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 03 February 2014 - 10:12 PM
my dad has a cracking 998 in his '73 which my brother put together for him,
its much like some of the others really,
pocketed block,
12g940 head that was ported and had the chambers tidied up
kent 266
hif38 with a k&n
cooper freeflow, twin box rc40
and that is about it, made 80bhp and 70lb/ft torque on hi-tech rolling road a couple of years ago, the same day i took a customers 1275 which made 63bhp!
it drives great and really does rev very easily, i would like something similar in my metro when i get round to it.
#35 marrrk
marrrk
    Just On Tickover
  • 6 posts
Posted 05 February 2014 - 05:09 PM
A-series 998cc Block + 0.40'' Skimmed, pocketed, oil and water channels mod for the 12g940
Bladed, polished and balanced crank (A+)
Lightened polished and balanced Rods (A+)
Stage 3 12G940 whit STD valve size (33/29) special made for this engine, giving about 10,5:1 Compression Ratio
STD flywheel lightened
Minispares light back plate
Keith Calver RE13OT camshaft
Lightened cam followers
1275 Pressed steel Rockers (1.27:1)
Lightened Duplex Vernier, full adjustable
Hif44 carb, on howley maniflow, modified to match the 44
3" Pipercross rampipe
Freeflow manifold, SS centre line, and rc40
STD 998 A-series gearbox whit 3,44 final drive, full recon and reinforced diff whit EN24 pin, windage tray fitted
Running on Bestek ignition, Rally curve
Soon I will change for Megajolt and customize the needle
How was the 998 on the road with the RE13OT?? Leaning towards it in my fast road 998!
#36 Gremlin
Gremlin
  • 2,142 posts
Posted 05 February 2014 - 06:37 PM
pocketed block,
kent 266
hif38 with a k&n
80HP! Really?
#37 minimk1
minimk1
  • 917 posts
  • Local Club: a's of herts
Posted 05 February 2014 - 08:28 PM
slight change of plan for me, the cooper engine is sold and i have recently put my 998 in
spec:
mg metro cam
lightened followers
stage 3 modified 12a185 head
maniflow manifold
twin 1 1/4 su carbs and trumpets
works rally exhaust
duplex timing chain
hoping for 50bhp
#38 minimender
minimender
  • 1,589 posts
Posted 05 February 2014 - 09:09 PM
spec:
mg metro cam
lightened followers
maniflow manifold
works rally exhaust
duplex timing chain
hoping for 50bhp
If you want to save money then no need really for the lightened followers or the duplex timing chain, I would have thought that  one will cancel the other out weight wise, all your power will come from the head and manifolds, you might consider an MG distributor to match the cam, with head cam, dizzy, and extra breathing you should see 50 bhp quite easily
#39 minimk1
minimk1
  • 917 posts
Posted 06 February 2014 - 06:55 AM
already fitted the engine and just looked at the recipt they are just the std ones but i have also fitted the duplex chain however i got that for £15 so doesnt effect my budget too much.
what type of mg distributer should i be looking at ??
thanks for the help
#40 coopdog
coopdog
  • 4,506 posts
Posted 06 February 2014 - 10:41 AM
thanks for the help
I got 64bhp out of mine, you should get 50
#41 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 06 February 2014 - 11:34 AM
998 +20 pocketed (1014cc)
County flat top pistons
Early mg metro cam
Standard 12G940 head - thought better of the big valve one..
Duplex
Currently on hs4, but might put an hif 38 on. Any other suggestions?
RC40 single box
Will get it rolling roaded in 200 miles or so.
#42 coopdog
coopdog
  • 4,506 posts
Posted 06 February 2014 - 01:44 PM
Early mg metro cam
Duplex
RC40 single box
Sounds like you have it all covered, only other thing would be a lightend flywheel or a different carb
#43 jt19
jt19
  • 745 posts
Posted 06 February 2014 - 02:26 PM
my old 998 had a maniflow system on it with a very good head on it. 3.44 fd hif 38 and it was fast for a 1 litre.
i had a mate follow me in his bmw to see what speed it was really doing as it would go right round to the M on MPH on the slandered 90 mph clock. I had the correct speedo drive fitted aswell!
It would do 100mph exactly!  Which I didn't think was too bad :)
#44 patto
patto
  • 199 posts
Posted 06 February 2014 - 10:49 PM
Just wondering if anyone could be give me an estimate on what you think my spec would produce?
998 +.80
Pocketed
12g940 head (standard)
266 kent cam
Steel/alloy vernier timing
Mini spares lightened flywheel
Flat top pistons
10.4 CR
Lightened dizzy drive
Polished con rods
Maniflow single box system
HS4 and alloy manifold
#45 coopdog
coopdog
  • 4,506 posts
Posted 06 February 2014 - 11:37 PM
998 +.80
Pocketed
266 kent cam
Flat top pistons
10.4 CR
Polished con rods
60+
