Stupid Things You Have Done Whilst Working On Your Mini
81 replies to this topic
#31 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 21 August 2011 - 09:42 PM
when fitting my rear hilows, the axle stands i borrowed were taller than the max height of my jack.
so i put the jack on some hefty blocks of wood.
i finished and lowered the car down, only to realise the tyres were rubbing on the arch.
but couldnt jack it up as it was so low, i couldnt get the jack ontop of the wood combo back under the car.
#32 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 21 August 2011 - 09:55 PM
hit myself in the face with a panel hammer, was trying to lever a seam so it would be straighter and i was pulling towards myself and it slipped and hit myself in the face :( would have saved time getting pliers which i did after that :lol:
#33 Bluecray
Bluecray
  • 140 posts
Posted 21 August 2011 - 09:59 PM
Making sure car was ok for MOT, decided to replace one of the washer jets, used mole grips to undo nut, and replaced it.........
Car went for MOT, passed :-) MOT tester, said he found the mole grips in the engine !!!! I felt pretty sheepish!!!!
#34 Brookesy
Brookesy
  • 507 posts
Posted 21 August 2011 - 10:10 PM
Had just cleaned the engine bay and had started to paint bits and bobs. Took out the dip stick as it was in the way. Unfortuantly forgot to put it back in so ended up with a nice unclean oil covered engine after driveing to work the next day!
#35 1badsmell
1badsmell
  • 13 posts
Posted 22 August 2011 - 01:03 AM
Jacked up the rear of a mini to check for a noisy wheel bearing
Span the wheel really fast to listen ....
Suddenly noticed my fingers being forced past the radius arm pivot in a kind of mangle style fashion.
Removed a lot of skin from most of my fingers.
#36 IS300
IS300
  • 104 posts
Posted 22 August 2011 - 08:32 AM
ran a brand new race engine in by racing a 1.8 zafira (and winning) and putting it on the rolling road >_< :withstupid:
#37 stocky
stocky
  • 338 posts
Posted 22 August 2011 - 10:20 AM
My dad removed a stubborn circlip once and he managed to smash his front 2 teeth in, I laughed my ass off at him
#38 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 22 August 2011 - 10:53 AM
when i was replacing the cylinder head gasket on my 998 i forgot to put all the pushrods back in before putting the rocker assembly back on.
#39 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 22 August 2011 - 11:11 AM
I'd always forget to turn my fuel pump on after leaving it in a car park. So half way into a journey it'd start spluttering and die, I'd end up taking the front end off to see whats up, checking spark etc before realised fuel pump >_< Flick the switch and bam back on the road
#40 bobs
bobs
  • 512 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 22 August 2011 - 11:25 AM
Refitting my cyl head did an oil change too, filling the oil after a change, and thinking why is it taking so much... it wasn't until the oil seeped out under the front of the car that I realised the rocker gasket wasn't sealing at the back... took ages to mop all that off the garage floor... and the smoke off the manifold, pheeew!
This weekend watched my brother struggle with the hub nut on one of his radius arms, it wouldn't come undone, wasn't until after I giggled at him putting the air impact wrench on it, I said... "sure that side doesn't have a left hand thread?" then ran as tools and swearing came flying my way for just watching him wrestle with it and not reminding him!!
#41 89mini-boy
89mini-boy
  • 486 posts
  • Local Club: OXMOC
Posted 22 August 2011 - 11:52 AM
i brought a gorgous mountney racing wheel (red completley original £15) got home took all the bolts off and replaced with new shiny st st, well when it come to putting it back together i tried pushing the boss back into place ontop of the ring and to my annoyance it wouldnt fit, so i tried and tried saying it came of this way it must go back on O_O. Well then gave it to my dad for him to try and he had bent it because of all the force we used :shy:, after this we found out that actually you place the ring on top of the centre boss then bolt them together. Well i was in tears :cry: and steering wheel was ****ed. so i cut through the side of it and then welded it together flat (well not bent) and now all i got to do is give the 15mm square space a black touch up job and will look good as new, so happy ending.
But could have been avoided, so....when you take stuff apart always see how it comes apart so you know then you wont balls it up putting it back together.
(im seventeen and will never make this mistake again.... hopefully)
Ashley
#42 89mini-boy
89mini-boy
  • 486 posts
  • Local Club: OXMOC
Posted 22 August 2011 - 11:57 AM
Whilst watching family guy. My dad decides to tell me how to remove my track rod end.. and as ii could tell that this would be a lecture i turn full attention to the telly!! All i heard was as family guy finishes is you might have to hit it with a hammer! So totally blind with ignorance I take off the nut like it says in the Haynes manual and I hit it with the biggest lump/mallet I could find.. smashing a track rod end and now having to get it tracked XD Costing me more money :L
hahahaha you always make me laugh chris
>_<
#43 ThunderJimmy
ThunderJimmy
  • 121 posts
  • Local Club: www.street-legal.biz
Posted 22 August 2011 - 01:00 PM
Oh so many... probably the most costly involved 2 minis and an ill placed jack.
So Kerbed a wheel in my mini, flattened the tyre and limped home on the spare. I decided once back to swap that spare for a 6 x 12 minilite from my brothers (unused at the time) mini until I could get mine repaired.
Got a scissor jack under my brother's mini at the passenger side jacking point and proceeded to crank, took the wheel off, went to fit the spare from mine and found that the axle was hanging too low to the ground to squeeze the wheel on... Thought this was strange and so got another jack under the subframe to raise it from there. All good, job done....
Turns out my brother's sills were rustier that Simply Red's nutsack and had bent quite considerably around the jacking point, meaning the door no longer shut. It's a good job he was in Korea without a clue O_O
Changing wheels shouldn't be that much drama >_<
#44 retroracer1275
retroracer1275
  • 543 posts
Posted 22 August 2011 - 01:19 PM
changed the cv joint in a good time, bolted everything back on wheel etc, lowerd the jack and packed the tools away only to realise the cv boot was on floor behind me :(
#45 ZKruly87
ZKruly87
  • 114 posts
  • Local Club: Mini Wips
Posted 22 August 2011 - 01:29 PM
had my car on jack stands to do something or another. i think it had something to do with the speedo or diff. just as i crawl out from under the car the stands sink on there side into the wet gravel in my driveway and the car falls to the ground. i was well out of the way but you can imagine the feeling.
car was undamaged. pride not so much.
Edited by ZKruly87, 22 August 2011 - 01:30 PM.
