Stupid Things You Have Done Whilst Working On Your Mini
81 replies to this topic
#61 Cooperman
  • 23,305 posts
Posted 23 August 2011 - 06:33 PM
I once flattened a battery, then realised I had left the :withstupid:
But, and I didn't do this, a friend of mine had re-built a very nice 850 engine and he asked me to check the installation and the timing. I did all that and he then asked me to do the initial start up. I did the usual - plugs out, spin it to get oil pressure, plugs in and it started and ran superbly. Let it run at 1500 to 2000 rpm for about 20 minutes, then switched off, checked it all and re-started it. My friend asked me to reverse it out, so put it in reverse and gently let up the clutch - nothing! Checked the clutch linkage, all OK.
"OK", says I, "Where's the bit you left out?" Sure enough, right there, under a piece of rag, was the transfer gear.
Three hours later with the two of us doing it, off it went down the road and it ran beautifully.
#62 ChrisG10
ChrisG10
  • 308 posts
Posted 23 August 2011 - 07:39 PM
Stripping out the engine.. About to put it back in thinking I have sealed all the gaskets go to fill it with oil and the rocker cover gasket wasnt sealed.. OIL ALL THE WAY DOWN MY LOVELY ENGINE!!! :( and then went on the garage floor and has stayed there as i cant be bothered to clean up
#63 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 23 August 2011 - 09:28 PM
A mate of mine took his head off ...
Ouch!
i too read it as this first thought christ is he ok :o
I bet he wouldn't have been :lol:
#64 mohammed
mohammed
  • 433 posts
Posted 24 August 2011 - 03:26 PM
was flushing the rad and engine.. to out the thermostat to flush the engine..when put the thermostat housing bak on after tighening all the bolts i realised i forgot to put the thermostat in.. so unbolt...what a time waster..
#65 davej
davej
    Kelly Jones
  • 985 posts
Posted 24 August 2011 - 06:13 PM
I`ve set me jeans on fire a couple of times while wedling. My brother in law, dad and sister were in the garage once and all started laughing me as I try to put the flames out.
#66 jackgreen91
jackgreen91
  • 205 posts
Posted 24 August 2011 - 11:08 PM
I also set fire to my trousers while welding. damn nearly hit my pizzle...a lucky escape.
#67 Swainy
Swainy
  • 319 posts
  • Local Club: Sexy People Only Mini Club
Posted 25 August 2011 - 10:51 AM
Hahahaha pizzle. That's a new one! :)
#68 GregH
GregH
    Is Praying To The God Of Wheels Right Now
  • 261 posts
  • Local Club: P&SMOC
Posted 25 August 2011 - 11:43 AM
Connected the battery up the wrong way round, bye bye altenator.
Set a rag on the inside of the mini alight while welding the inner sill, that cought my rear seat alight. I couldn't see through the car because it was so full of smoke.
There must be others but i try and forget about these.
Gregh
#69 jaydee
jaydee
  • 8,565 posts
Posted 25 August 2011 - 02:32 PM
I've one of those magnets that go above the oil filter to trap metallic swarfs, like this one:
http://www.minispare...id=42212&title=
You can see it has a rubber gasket on top, oil filter gasket will seal at the bottom.
Problem is that, i dont know why, i've fitted it upside down, then started the engine over..bang oil squeezed everywhere!
#70 R1minimagic
R1minimagic
  • 4,660 posts
Posted 25 August 2011 - 02:46 PM
Lots of things that are far too stupid to mention on here! :lol:
#71 mike.
mike.
  • 6,176 posts
Posted 25 August 2011 - 03:01 PM
Rebuilt my engine without the transfer gears!
Luckily remembered before I put it back in the car!
#72 AntonyC
AntonyC
  • 55 posts
  • Local Club: NA
Posted 25 August 2011 - 06:12 PM
I fitted a new headining recently using spray ahesive glue. While i was waiting for it to go tacky i was fiddling with the door card, quickly looked up to see if it was tacky and it dripped straighted into my eye! I must have time it perfectly lol
Anyway i ran inside and prised my eye lids apart and kept washing it in eye solution before being rush to the eye hospital. The nurse said i was very lucky and only had a slight burning the eye. Had a week of putting in this thick white cream in my eye which was not very nice.
A lesson learnt, i always wear glasses when applying glue now :)
#73 zeemax mini1
zeemax mini1
  • 47 posts
Posted 26 August 2011 - 10:52 AM
With the car locked and my tools locked securely in the boot, I put my keys down on top of the air filter housing, so that both hands were free to fiddle with something in the engine bay. When finished, I then closed the bonnet with the keys still sitting on top of the air filter..... unfortunately I have an internal release bonnet!! >_<.
What's worse is that I've now managed to do this on two occasions!! :withstupid:
aha if i locked my car with the bonnet open the alarm would go off so this should not happen to me ! :)
#74 adam_mini
adam_mini
  • 394 posts
Posted 26 August 2011 - 02:52 PM
I once fitted all 4 wheel trims by removing all 4 nuts, fitting the trim then fitting the nuts back on without jacking the car up. Luckily the wheels didn't come off else it could have ended in disaster >_<.
I now have alloys so shouldn't be able to do this again :rolleyes:
Edited by adam_mini, 26 August 2011 - 02:52 PM.
#75 lapider
lapider
  • 473 posts
  • Local Club: cardiff mini club
Posted 26 August 2011 - 11:33 PM
My dad was once restoring a mini and he drove it to his local garage where he lived in a small town in the Brecon beacons. On the way back to his house he had to drive through a village road then down a windy, narrow single country lane with the mini missing its doors,boot and all its glass. In the back he had a load of nuts and bolts assorted into jam jar and ice cream boxes and the doors and boot on the back seat. As he drove back he passed the local bobbies parked up in a lay-by. He drove so fast through the lane and lost all the nuts and bolts as he went over the bridge.
