Engine Strip Down And Rebuild With Lots Of Confusion :d
#16
Posted 16 December 2011 - 06:57 PM
#17
Posted 16 December 2011 - 07:05 PM
Think I'll take it down to an engineering firm and get it sorted out.
That's what I thought but if it slipped it wouldn't be sitting in the opposite side perfectly snug but I'm thinking that could only be the case as there would be some damage if it happened in the engine during use.
Will upload photos of pistons see what people think going to flicks now to see sherlock Holmes might crack on a bit more tomorrow after work
#18
Posted 16 December 2011 - 07:49 PM
Apologies for multiple replies on iPhone bit of a glitch will delete later
#19
Posted 18 December 2011 - 05:24 PM
what do people think about this damage
#20
Posted 20 December 2011 - 08:04 PM
#21
Posted 21 December 2011 - 10:22 PM
#22
Posted 21 December 2011 - 11:35 PM
When rebuilding mine one corner of a piston was a bit pitted, I give it a light emery rub, reringed it and reused it, touch wood its been fine
its up to you though, new pistons are a pricey affair
#23
Posted 22 December 2011 - 10:56 AM
#24
Posted 22 December 2011 - 12:05 PM
#25
Posted 22 December 2011 - 12:28 PM
#26
Posted 22 December 2011 - 06:32 PM
Getting a new radiator but will look into lighter flywheel cheers
#27
Posted 22 December 2011 - 06:35 PM
Can I clean the gearbox/transmission out with all parts still intact?
#28
Posted 27 December 2011 - 12:13 PM
Oil gallery plugs there should be three on a 1275 is that correct? i only found two on one side one was open up already for a securing bolt?
Got the block bin soaked in jizer now going to clean it down and strip the paint then work on the head.
Can the piston bores just be polished down with a polishing kit.
#29
Posted 27 December 2011 - 12:23 PM
#30
Posted 27 December 2011 - 03:53 PM
